power adapter jack a1139
My factory power supply is fine. POS ex wife tripped over the thing so many times the barrel-connector at the end finally wore out right at the connection. i'm on a tight budget and can solder another on if there's a replacement available (pref with wire leads in place). do you guys have any idea where to run one down?
Score -1
1 Comment
Haha....no, I meant what you think. I think 1/2 the time she did it on purpose! ;-) I think you misunderstand, I mean just the little lighted barrel-gonnector on the end of the power adapter. I broke free from the wiring and the connection is bad somewhere in the little chip set that makes it light up. Surely....lots of folks have had this happen....hence, the mag-safe stuff on the MacBooks, huh?
So, any idea where to get that type of barrel-connector that I can splice onto the end of the power adapter?
Thanks Markus, Matt
by
Add a comment
1 Answer
Chosen Solution
The easiest way would be replacing the dc-in board:
[linked product missing or disabled: IF155-065]
depending on your soldering skills and the the condition it might be possible to solder the old one in - if that won't work - maybe you should search the part on ebay
and btw - i hope you meant "princess of sheba" with POS ;-)
Score 2
3 Comments:
Thanks Markus,
Matt
by
ok, now i get it ;-) here is a guide to repair the connector: http://www.instructables.com/id/Repair-y...
by
+ Ralph
by
Add a comment
Add your answer
matt lauter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,730
