The iMac is Apple's line of all-in-one desktop computers.
8383 Questions View all
Question Closed
What used iMac model to buy, 27" 2010 or 2011
Sorry for this question - i'm a poor graphic designer and i need to buy a second-hand iMac 27.
Please what is the best model-year? Early/late 2010/2011?
In the future I'd like to update: video card + hd
What model i have to buy to do this?
Many thanks!
Mario
*(2012 is too expensive and now i work with a imac24 2008)
**(I see that 2011 have some problem with video card)
Add a comment
Most Helpful Answer
Updating video cards is a no-go for iMacs, since the video module is specific to the motherboard. The only Intel Macs that permit video upgrades are the aluminum Mac Pro towers (2006-2013), which have AGP and PCI-E slots. Even then, the card you install has to have an OSX driver.
I agree with mayer: You're much better off getting a 2011 iMac than a 2010, because the Mid 2011 model is the first generation with Thunderbolt ports. This makes the computer far more extensible, since you can attach all kinds of external devices (hard drives/drive arrays, giant monitors, FireWire/USB 3.0 gadgets) without the speed limitations of the onboard FireWire and USB 2.0 ports.
A lot of external drives now come with USB 3 interfaces, which are much faster than USB 2. Although the iMac didn't get onboard USB 3 ports until the Late 2012 generation, you can get USB 3 ports by using a Thunderbolt breakout box available from a variety of manufacturers including Akitio, Belkin, CalDigit, Matrox, and Sonnet. You can also get Thunderbolt drive housings, which can give you external storage nearly as fast as the internal drive - maybe faster, if you're using an external solid-state drive.
The video repair extension mayer links to in the 9to5 Mac article isn't currently posted on Apple's support site, but it may be an issue the Genius Bar addresses as affected computers show up. There is a different repair extension with failed 1TB hard drives, which applies to iMacs from October 2009-July 2011, so you should be aware of it.
Score 2
2 Comments:
Time to claim your free T-shirt from iFixit for going over 500 points in reputation. Keep up the good work ;-)
by
I've already got a T-shirt, from when I staffed iFixit's Maker Faire booth a few years back. I should see if they'll give me the pentalobe bits that weren't in the older revision of the 54 Bit Driver Kit instead, so I can get post-2010 stuff open...
by
Add a comment
Go for the 2011. If the video goes bad Apple will fix it for free: http://9to5mac.com/2013/08/16/apple-open...
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,632
