Removing LCD from digitizer
Is there a way to remove LCD from digitizer?
vonta30, not for the common DIY'er. The digitizer and LCD are bonded together. In order to separate it, you would need some very special equipment. Even if you have it separated, you will still need more special equipment and adhesive to reassemble it properly. I suggest that you replace the complete display assembly unless you have the right tools and expertise. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 189
