Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
White screen after screen replacement. No home button
Okay so I bought a 16gb ipod touch for $4 with a broken screen and bought a replacement for $22.
the ipod worked fine before swap. I couldn't turn off the ipod but once I got the sceen on I tested it and it turned on and worked fine. I started to put the screen back together then I tried it again and It didn't work. Black screen and iTunes didn't recognize.
Started messing with it and I the white screen now. I tried the home button thing and didn't work. I believe my home button is broken also. But I don't have that little spring in nor did I have the little bracket in. but I didn't have it in when I tested it. and it worked fine. Someone please help
Score -1
Add a comment
1 Answer
Has nothing to do with the spring or bracket try a hard reset my holding power and home button togeather at same time for 7 seconds then let go of the home button.. Make sure screen connection is seeded correctly
1 Comment:
My home button doesn't always work. I'll try it when I get home
by
Add a comment
Add your answer
Preston will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 73
