Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Lost 3.6 mm standoff screws
So I lost the 3.6 mm standoff screws that hold the lower half of the logic board into the iPhone. I have purchased multiple screw kits hoping to find what I'm looking for. What do you suggest I do? Is it possible to purchase the standoffs or is there a way around this around this problem?
Thanks
Score -1
Add a comment
1 Answer
Putting the iPhone back together without these two screws will not cause any problems, that I can predict. The upper one (mid logic board), you will lack screw hole for one side of dock flex connector cover plate, should be no issue. The lower one, you will not have the logic board held down next to the battery connector, and you will lack screw hole for the battery flex connector, should be no issue -- until you remove battery in future, the logic board will not be perfectly held down here when you remove the battery flex connector, it will pull up the logic board a bit, but should not be a problem, but be very careful when removing the battery flex connector from the logic board as always.
Add a comment
Add your answer
tolison26 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 343
