Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Why my fan sounds weird?
Hello folks.
My fan began sounding weird.
I'm not sure how to describe a sound. I only heard air moving, today it sounds more like an electric motor, like a loud hard drive.
I popped the lower case, fan is a bit dusty, but it does not look clogged or obstructed.
What can it be? Is there any DIY remedies I can try?
Add a comment
Chosen Solution
don't use WD40 to lubricate your fan instead use sewing machine oil. Check this link and you'll know why:
http://www.techrepublic.com/article/quie...
Score 1
Add a comment
You can try lubricating the fan with a light oil. Just pull the blade assembly off the fan and put oil on the pin. However, you should replace the fan as the lubrication doesn't last long.
1 Comment:
Does it mean fan is dying or does it just need maintenance?
Is there some specific reason for a fan to go dead, I'd like to know if there are steps to prevent the next one go bad.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 148
