Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
No charging or data connection
Got an iPhone 5 in where the customer had attempted to change the power/volume flex. In so doing he's done something to the lightning connector as it won't charge or connect for sync.
I've changed out the lightning connector assembly and replaced with a new one, no change at all. Had a close look at everything and can't see any damage. Tried two new lightning connector assemblies now so pretty confident it isn't that part.
It's odd as he's actually managed to replace the power/volume flex properly, but I'm at a loss as to what he's done to cause this issue. Any ideas what it might be that is broken?
1 Comment
It certainly seems that the damage is to the logic board but I've looked at this and compared with a working one and can see no dislodged components. I think I'm going to have to give up on this one.
by
Add a comment
1 Answer
Most Helpful Answer
He has damage some part of the logic board seems a comon issue with the 5 .
As you no yourself all the little components on the board around the battery area and were the charging port connects could be easily knocked off if you don't no what your doing
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 90
