2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Question Closed
power button and several keys not working
I have a white macbook White late- 2009 A1342 macbook Duo
The power button and several keys on the rights side of keyboard do not work . Can only power up by jumpstarting.
Any way to further diagnose tried pram and smc reset.
Might I need to replace ribbon cable or keyboard/topcase
Add a comment
1 Answer
Chosen Solution
Yes - top case replacement. Sounds like spill damage. Check in side for corrosion.
If this answer is acceptable please remember to return and mark it.
Score 1
2 Comments:
No spill damage but maybe keyboard cable was damaged? Do I still need new top case - any way to put in new ribbon cable only. New topcase $150, used macbook ebay $320 best choice?
by
You can start with the cheaper fix… I have no way of knowing where the damage is. If you need/want other parts on hand maybe the used MB is a good investment.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 674
