Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Question Closed
Track pad does not select
I have a Macbook pro 17in and my mouse moves around on the screen, but does nothing when clicking or selecting an item.
I checked to see if the battery was swollen, and it is not.
I believe I need to replace the track pad, but I'd like to make sure before doing so.
Add a comment
Chosen Solution
Yes you'll have to replace the trackpad but you can also use the tap function that act like a clic. Check the trackpad module in system preferences.
Score 2
Add a comment
Remove the battery and adjust the trackpad adjustment screw.
Score 1
Add a comment
Like mayer said, try adjusting the trackpad adjustment screw, but give it a couple of tries before giving up. It takes a while to calibrate to were the trackpad clicks again.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 199
