Score
Marc
13
Asked
Battery won't charge up - only works when plugged in.
Hi,
It got to the time when the battery needed to be replaced, or so I thought. I took it to a repair shop who installed a new one, after which they told me I was good to go. Once the battery had reached its max paying time, I plugged it in (for several hours)for it to recharge. However, when it came to unplugging it in view of listening, again the battery stated it was out. I tried different chargers, both through the mains and a computer. So, I brought it back to shop where I left overnight so they could take a look at it. The next day, I returned to find that they had tried multiple batteries but the device still wouldn't charge. I can now only as a consequence listen to it plugged into the wall. I suspect there is something wrong with the motherboard but not too sure. Can you help?
2
Score
Crisb
1.7k
Answered
0
Score
Aram
254
Answered
0
Score
Answered
I may have the same problem. my 160 gb ipod wont take a charge from wall or usb port. Is my battery dead? I do get a green charging icon and left it pluged in wall overnight but when i unplug it its not charged up. i can access my media on it (i have over 100 gb on it and its my friend and lifeline ) when its wall pluged and can access the pods main menu where it has function of reset to fact specs but that means i lose it all right? and would this fix charging problem? someone please help, if its the battery that would be fine i can get one online inexpensive and if you can tell me how to put it in that would be great, but can anyone help? Thanks Joseph
since the batteries are inexpensive - i would try that too. use the battery guide - the needed tools are listed inside the guide
0
Score
Morgan
Answered
I am having a similar problem! My iPod Touch 8GB 3rd Gen will run on the wall charger, but when I take it out to sync with iTunes or to use, it cuts dead immediately. I have replaced the battery, screen and digitizer. Please help, I live on my iPod and have so much stuff on it!
Please reply to morganggregg@ho
Many Thanks
mggregg
Morgan, it is a lot easier if you ask your own question. Nobody sees that you are having a problem with your ipod since it looks like you answered an old question. Also it is not necessary to give your email address unless you like to receive a lot of spam. You should never really publish your addy publicly. Ask you own question and someone is going to help you, rest assured. Good Luck
0
Score
bjoernen dk
627
Answered
If it won't hold charge, and did with the old but worn battery, possibly something happened during the repair. Could be that the motherboard has been soiled or corroded. If so there is a chance that it can be cleaned (I managed when my iPod had similar symptoms).
You could go to the shop a tell them that the malfunction started after the repair, and would they accept responsibility. When they answer no, ask if they could - only from their wish to be helpful - give you a cleaning liquid plus instructions (there is repairmanuals on this forum if they prove to be completely uncooperative).
Several cleanings might be necessary. Focus on the area closest to the battery ribbon cable connector.
Good luck
I have currently attached your question to the page for the 5th Generation iPod Video. Let me know if your model is this one, or the 6th Generation iPod Classic, since both have 80 GB versions and video capabilities.
David Hodson,
Actually I think it's the 6th gen classic. I always get mixed up!! Thanks.
Marc,
