Is there any repair for netgear wireless router?
router is not receving power from the cable. can the router be repaired? if yes how much does it cost????????
awaiting your reply...
To start with have you tried a second power transformer. If you look on the bottom of the unit you should find a diagram which will tell you the units power requirements. I would suspect it needs 12volts 1Amp and the plugs inner core is the positive contact. Please double check this and locate the needed unit. What happens when you plug in the other unit and you press the power button? Does any LED's light up at all?
Any luck getting a new power transformer?
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 9
All Time: 946
8 Comments
please anyone do suggest me to solve this problem
by vamsi krishna
Can you give us the products name & model number of your unit.
by Dan
NETGEAR Wireless-N150 Router WGR614
by vamsi krishna
vamsi krishna, "not receving power from the cable" are you saying that the router does not turn on? Receives power from what cable?
by oldturkey03
Here's a good resource Netgear N150 Router documentation
by Dan
Show 3 more comments
