Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Keyboard and trackpad not working
This one time I started my laptop and it started searching for bluetooth mouse and keyboard, even though they are integrated. So I began using it with external peripherals and it worked. I tried to see if it was a software problem and it wasn't. So i decided to get it fixed and they now say that i would have to repair the entire logic board, which would be quite expensive. Is there a cheaper solution for just fixing the part that affects the keyboard and trackpad? Failing that, could i get some tips on modding so that that logic board doesn't go to waste?
Score -1
Add a comment
1 Answer
Chosen Solution
Can you give us some back story here? Did you spill something into the keyboard?
I can't see the need to replace the logic board here. If you messed up the keyboard & track pad then the top case may need to be replaced. Granted, its a lot of work and it isn't a cheap repair but if your able to do it your self. Do you have the skills and tools?
Score 1
Add a comment
Add your answer
Bosco Vallejo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 6
All Time: 282
