Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Questions View all
Question Closed
Do you need to buy a certain size hdd?
I just bought an a1237 and I need to replace the hard drive and before I go buying something I want to know if I have to buy a certain size for the laptop or if it's just a regular hdd?
Add a comment
Chosen Solution
Yes - if you don't get the correct HD it will not fit or work. It must have a ZIF connector not SATA and it must be 1.8" form factor, 5mm thick.
If this answer is acceptable please remember to return and mark it.
Score 1
1 Comment:
Thank you so much that helps a lot!
by
Add a comment
You need to know the size and type of hard disk in the System before you purchase. There are various forms of hard disk, although most System use the SATA now.
1 Comment:
In the Air's the "hard disk" is an SSD.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 95
