The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Questions View all
Question Closed
Disk Drive Replacement/PCB Board Swapping
I'm looking to replace a faulty disk drive, (Model: Philips-LiteOn DG-16D4S). The xbox slim is out of waranty and the drive will not read disks of any kind, (open tray error every time).
I want to physically insert my current PCB board which has its security key into a brand new drive of the same model. I understand this requires some soldering. I'm not interested in flashing or any kind of software manipulation.
My two questions are: Will this work and now be able to boot games? And, if I go online with this repaired disk drive is there a chance my console may be banned?
Add a comment
Most Helpful Answer
You will be okay going online with it. Since it will be the same key that belongs to your machine. Yes, this would be the way to do it to replace the drive.
Score 1
Add a comment
I just did the same exact repair today it work. It will work exactly the same electronically and software wise. The soldering is very simple. half a dozen wire to connect individually.
If you found my advice helpful, 'accept' my answer, and click the up arrow :)
Score 1
1 Comment:
Hey james, do you have any pictures of this? i would like to see how to do this, thanks.
by
Add a comment
The only smart part in the drive is the controller board. the rest is just motors, sensors, blah blah blah. The console will not detect any security breaches even if these parts are missing
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,723
