has a grey screen with a spinning planet and says choose network
what do I do when my mac book pro has a grey screen with a spinning planet and says choose network
It sounds like your system is looking to connect to Apple servers to do a system recovery as the OS files are damaged.
Do you have a network you can connect your system to so it can recover its self? If not you can also do a re-install if you have a recovery drive setup or if you have a second mac you can set up yours in target mode and connect your system using either a FireWire or Ethernet Network cable to your other mac you can re-install the OS.
I should point out connecting to Apples servers can take quite awhile depending on the network bandwidth you have to the Internet.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 576
