Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 Questions View all
Question Closed
Fan speed to the max after superdrive replacement with SSD
I tried to install a second SSD drive in my iMac 27" (mid 2011). I followed the guide to install it to the free SATA port only to find out that I was missing the connecting cable. So I assembled back to the part that I had to place the superdrive and I used a caddy (which I already had) following the instructions here.
I closed the computer and installed Mavericks and found out that the fan was working at full speed.
I did transfer the thermal sensor from the superdrive to the caddy. Does anyone know what could be wrong?
I when through all the cables to check if anyone was not correctly in place and still have the fan at full speed,
Other than that the iMac is working extremely fast and without any other problem.
Add a comment
1 Answer
Chosen Solution
I don't think you can use the optical drives cable as the system is expecting an optical drive on the other end.
I would recommend getting the correct SATA cable and see what happens then.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 424
