The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Questions View all
Can Nexus 5 use battery from LG G2?
Hello,
Nexus 5 and LG G2 are very similar. There is a good chance their batteries are interchangeable.
If so, that would make it a cheap upgrade to 3000mAh for Nexus 5.
Thank you,
Sergey
Score 1
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
Chosen Solution
Hi Sergey, thanks for the tip! I looked into it a bit, and it looks like the batteries have incompatible connections.
From xda-developers forum, the LG G2's battery has its connection on the top left of the battery:
From our teardown, the Nexus 5 battery connection is on the top right:
Score 2
1 Comment:
Connector is easily moddable. But the real issue is that BL-T7 is 7mm longer - won't fit anyhow. Thank you!
by
Add a comment
how about the lg g flex battery? looks like the connector is on the same side as the nexus 5 battery...
http://www.servimg.com/image_preview.php...
Score 1
Add a comment
Are you aware of any batteries that may be suitable for an upgrade?
Add a comment
Would someone tell us the dimensions of the nexus 5 battery and the dimensions of LG G2 battery?
Add a comment
Add your answer
Sergey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 17,922
