13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Question Closed
Recommended SSD for MacBook 2008
Hi
Im new here, hope I have post in the right section,
Can anyone recommend a ssd for 2008 macbook aluminium, have been looking at a 128gb samsung 840 pro, which has great reviews is this model ok
Thanks in advance
Add a comment
Chosen Solution
No, wont work too fast you require a Serial ATA (3 Gb/s) that's a SATA III (6GB/s) it's overkill you 'd have to jumper it down to work on your system. You'll have hangs and freezing if you don't.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Yes, the Samsung 840 Pro mentioned above will work perfectly fine. There are no jumpers to fiddle with. The current Samsung SSD models don't have jumpers at all, but are compatible with all three SATA versions.
I do agree that there are cheaper alternatives that won't make any performance difference on this old Macbook, for example the Samsung 840 (without "Pro") or even a Samsung 830 - if you can still fine one. As for current models, the Samsung 840 Evo is also slightly cheaper than a 840 Pro.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 375
