Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
How to replace infrared sensor and power LED light
I recently was trying to replace my hard drive and severed the LED light from the infrared sensor. I am having a heck of a time trying to replace this component. Is there any tricks to removing the LED power light and IR sensor?
Thanks,
William
Score 1
1 Comment
Hey
I dameged this part when trying to fix hard drive and its flat cable cut down, but right now my laptop doesn't turn on.......what do you recommend...?
by
Add a comment
Most Helpful Answer
You know, I was asked this very question a while ago and endeavored to replace that part. With a small stack of junk cases, I did not manage to successfully replace any of them. They are just situated in the case with plastic reinforcement to not be removed! Replacement would involve re-melting small plastic pieces together, which isn't feasible.
Your best bet is to replace the lower case.
Sorry! At least you know it's not just you.
Score 2
1 Comment:
At least the remote sensor is functioning OK without the LED. I am going to leave it AS-IS until I damage my lower case. I appreciate your insight.
by
Add a comment
well, that happens when you do things you are not qualified to. But how will you learn but by trying? Keep up the good work, don't get discouraged - in the end you WILL win!
Score -1
1 Comment:
That's not exactly an answer. And not exactly too encouraging either
by
Add a comment
Add your answer
nrgflow will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,750
