Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
I get "Charging is not supported by this device" w/nothing attached
Contaminated my iPhone 3GS with a mixture of oil, sugar, soy sauce. (Korean BBQ Marinade)
Not much but just enough to cause the message "Charging is not supported by this device" when ever I wake the phone from sleep.
Everything seems to work and it will charge. The message goes away when the docking cable is attached.
What do I do as the Apple "Genius" told me I'm sol unless I want to pay full freight on a new phone.
Score 1
5 Comments
Thank you markus, after a bit of scrubbing with a brush and alcohol I am alert free. No disassemble required.
by
Can you accept his answers? Then he'll get credit :)
by
hi david,
great that it worked for you
²chris - yeah - would be a good idea - but the important part was that it worked
by
LOL, it's not just for credit, we do a lot of backend things based on "accepted" answers. When good questions like this get good answers I try to push to make sure the right answer gets accepted.
by
Ok, I liked the answer because it fit with my theory of what could be causing the problem. Technically it didn't "fix it" per say, but improved the situation to where I only get transitory messages telling me I have an unsupported device attached where before it was when ever I woke the phone from sleep. A tear-down and through cleaning would probably cure it, but I don't trust myself not to break a known good component in the process.
by
Add a comment
1 Answer
Chosen Solution
here is the guide to get the logicboard out
my magic glass orb told me that there is a shorted connection around the dock connector.
serious - the fluid has shorted something in the charging part of the phone, it ould be that is outside on the contacts of the dock connector - look closely, use rubbing alcohol and a soft brush to clean that area carefully - if there is nothing on the outside, it's inside the phone - but i'm pretty shure about the dock connector
if you see something slightly white/greenish (almost likt mold) - thats it - if you are lukcy - you don't have to replace anything - but be careful whith the disassembling
Score 2
Add a comment
Add your answer
David Nakase will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 8,577
