A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
85 Questions View all
Why is my Iron not heating up? when powered on
How do I get the Sun beam Steam Iron to work again?
Score 9
2 Comments
What's the model number?
by
I have the same problem now. Any chance that you get it to work again ?
by
Add a comment
Chosen Solution
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
Score 10
1 Comment:
replace cold iron
by
Add a comment
Ensure that the unit is tightly plugged into a working outlet. Some units are equipped with a Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat. Are you getting a red or green light?
Score 3
8 Comments:
I tried that but still cold. Red light is on. i
by
Is still green with no heating at all
by
the green light is blinking on my side but the red one not working
by
new one,
red
by
manandharmeena it it's new I would return it under warranty
by
Show 3 more comments
Add a comment
There is a small thermal fuse inline . This is usually on the red wire. Bypass this with a wire and check if it switches on. This happens a lot with the irons we use and i usually bypass the fuse if it blows a second one. But this is a suggestion and would be safer to replace the fuse by aoldering a new one in line
Score 2
2 Comments:
I need to replace my thermal fuse in my iron but do not know the rating, the writing on the old one has gone. What is a recommended temperature rating? Are all irons the same?
by
Thanks can i know the thermal fuse rating for Black & decker model no X850
by
Add a comment
Buy a new one, end of story
Score 1
1 Comment:
yes new onr but on low indicater not on only high indicator on how
by
Add a comment
Check the fuse in the plug this is common in electrical items to be blown
2 Comments:
no fuse in the plug
by
You must be using a 2 pins plug which is very dangerous in this high heat appliance. You need to use a 3 pins plug with the earth wire for safety reason.
by
Add a comment
Hi
I have the same problem with my iron. I no longer believe that my iron can be repaired, unfortunately.
But maybe anyone can recommend me how to choose electrical home appliances?
I read a lot of different reviews and it helps me a little on choosing.
Thanks
1 Comment:
Hi,
1. Desired features -does it do all that you want
2. Good warranty - longer warranties to me show that the manufacturer has faith in their product and are prepared to back it
3. Good aesthetics and ease of use - you've got to look at it and use it ;-)
4. Good reviews - speaks for itself
5. Best that you can comfortably afford.
Go for the one that ticks most if not all of the boxes.
Just my 2 cents
by
Add a comment
Add your answer
sahmarry will be eternally grateful.
Past 24 Hours: 36
Past 7 Days: 164
Past 30 Days: 648
All Time: 198,130
