Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
1 LSI indicator activated on battery
Hi,
I recently spilt lucazade on my MacBook Air. Turned it upside down immediately and left it to dry, was working, but turned it off to prevent further damage. It didn't turn on again, so I took it apart and a couple of LSI indicators are red. One LSI is red on the battery, but the rest are white. Does anyone know if with one LSI red the whole battery will need replacing or will it still work with 4 LSIs white?
Thanks!
Update
THANK YOU EVERYONE! I got it to turn on, only problem is the fan isn't working...I think is is a bit of a big problem, possibly I broke the connection, or it corroded from the sugar (1 week since spill now) Can I fix it? Also the speaker is now quite tinny, I don't mind so much about that, but suggestions are always welcome! I can upload pictures once I've got it open again
Update
They got it pretty bad, thankfully nothing went on the logic board as far as I can tell- the comouter has been rnning fine the last couple of hours. dont know exactly what is wrong with the fan, but i snapped the pastic part of the connector cable which holds it down when taking it apart. i figure this is just there to hold it in place though, so cant have caused the whole thing not to work? maybe the sugar corroded the metal parts of the connection? I had a bit of a 'nothing to lose' attitude before, but now I know it's working fine except for the fan, I feel a bit more worried. Any thoughts?
Score -1
1 Comment
May need to get a new fan and speaker. Did they get the worse of it?
by
Add a comment
Chosen Solution
Your drink has sugar & acids in it which over time will corrode things. The number of LSI markers that have turned on you is not what you need to focus on here. You need to clean what was spilled (even if its already dried).
You really need to take your logic board and the battery out so you can clean things off (see note at the bottom for more on the battery). Focus on the areas you can see wetness as well as where the LSI markers have turned red.
The best way to clean things off here is using distill water (not tap!) which will remove the sugars and dilute the acids. You will need to go over the areas a few times with a fresh cotton swab. Use a moist (not wet) cotton swab using a blotting action. If you do see any corrosion use a soft brush to scrub the area/s being careful not to pull anything off the logic board.
After you have gone over the logic board with distilled water you will need to go over it again this time you'll also use some 85% or better Isopropyl alcohol to wipe down the areas to help remove the water (acting as a dryer) and to remove any oils that may have been present in the drink. Again take care not to snag the swabs on the small components as you don't want to pull any off. You may need to use a small soft brush to scrub down any corroded areas again be careful! You can also use a can of can'ed air as well to help in drying. Don't forget to wash out the heat sink fins as well.
Batteries: Depending on how wet things got you may need to replace it. Distilled water or even Isopropyl alcohol can sort the battery so you need to be very careful on where you wipe down (get wet). I clean any surface areas that are still wet with what was spilled. I then put the whole system back together and then I turn the system back on running the battery down as far as I can. That way the amount of power is as low as I can get it before I do any deep cleaning of the battery contacts and wires (being careful not to create any shorts).
Post any pictures of areas that look bad so we can see the damage. We may have some ideas how to deal with them. - Good Luck
Score 3
Add a comment
Spills without triggering any LSI could still damage your device. Inspect and wash away any visible liquid spills, especially on the logic board and battery. Wait for it to dry and test the device.
Score 1
Add a comment
This answer was originally to another question.
It is possible that moisture/humidity could trigger a sensor - it's also possible there's corrosion you're not seeing because you're focused on the indicators. The more history and information you provide the more useful answers you'll get in return.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Laura will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,410
