Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
How to diagnose/repair water damage if GPU still works?
Mid-2009 Unibody 13" MBP
I spilled a small amount of beer on the top of the keyboard/hinge area. Turned the computer off immediately, but didn't wait long to turn it back on and after 20min of function the LCD died.
I hooked it up to an external monitor and have had continuous signal (had it on for at least 2 hours). Some parts of the logic board show hints of liquid damage, but all systems except the LCD seem to work fine.
My questions are:
-How can I further diagnose the machine to find any other problems that might also occur?
- The diagnosis I have given it points to the LVDS cable being damaged. If I replace that, are there any other necessary repairs/cleaning I should do just incase (ex: cleaning the logic board and all components with isopropyl)?
- I was quoted by a local authorized repair shop to completely replace the LCD assembly. I'm not sure that is necessary, is there any way I can check to see if the LCD itself is still functional (none of the liquid was near the screen, the machine was not submerged)
Score -1
Add a comment
1 Answer
Chosen Solution
To test the display you would need to plug the LCD into another similar models logic board, which is not very practical.
I would first look at cleaning up the spillage using some distilled water (not tap!) with cotton swabs after disconnecting the battery as the beer over time will cause more damage.
Score 1
Add a comment
Add your answer
Connor Pollard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,442
