Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Question Closed
Battery sometimes fails to properly charge
I've had this computer for a couple years now, and it's still running strong. The battery still gives me 4-5 hours charge, which is fantastic. The only problem is that sometimes the battery refuses to charge when my laptop's plugged in and the battery still has a good amount of charge (somewhere between 90% and 50%). Also, if I'm charging the battery from a lower charge, it sometimes refuses to finish charge - it says "Finishing charge" (or something like that, I'm not looking at it right now). What do you guys suspect the problem is?
1 Comment
I read somewhere that this is a known problem with the logic board. My macbook 2007 suffers from the same problem.
by
Add a comment
1 Answer
Most Helpful Answer
sounds strange - maybe the battery gives wrong data to the logicboard
did you try coconut battery to determine the original capacity vs. the current capacity
are you able to try a different battery - maybe it works normal with a different one (or not - that way you could rule out a battery problem)
Score 2
2 Comments:
I haven't attempted to use another battery, but my sister has the same style MacBook, so I'll definitely give that a try when I get the chance.
by
I haven't gotten any resolution with this, but I don't have the problem anymore. Perhaps just cycling the battery several times / the passage of time / software updates fixed it. Either way, I'm upvoting this answer so that the question is no longer "unresolved".
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 5
All Time: 1,131
