Adding bigger SSD
Hi there,
I was just reading the article 'Adding bigger SSD in Macbook Pro 13 inch Retina (late 2012)'
see: http://tinyurl.com/kmq8ozq
On the Apple site it says that bigger SSD's are available, but when I called my dealer, he said that that is NOT exactly the case.
He said that you can only choose SSD capacity (128GB of 256GB) you want AT PURCHASING time, so NOT afterwards retrofitting..
Bummer!!!
Then I learned that the SSD space in the MBP 13'' ALSO will fit a (max) 7mm height standard SSD, but that tHE problem is: the connector-cable between 3.5inch SSD and logic board.
It's hard to find full SSD's that have that new bus connector cable that will match the (new) connector on the MBP 13" Retina Logic Board...
OWC sells a SSD kit, max 480, but I need more capacity.
Can someone elaborate on the new type of SATA HD connector that is on the Logic Board of the Macbook Pro 13 inch, and where to get suitable (full size) SSD drives that have connectors that fit on the MBP 13" Logic Board?
Would be great to hear from you!!
Rgds
Robbert
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by iRobot
