2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
delayed Liquid Damage, some times turning on sometimes not
I have MacBook unibody, I spilled some tea + sugar on it. it turned off and then turned back on the next day and was fine for a week. I gave it to some guy to open it up and clean up the residues with isopropyl alcohol and let it dry. after putting it back together it would turn and it wouldn't turn off, after turning off by holding the power bottom it wouldn't turn on and it would turn on again after a while. the light indicator on the front stays on.
after consulting with many people these are the possible causes:
1-damaged nVida GPU --> logic board change
2-damaged topcase
3-damage in cables connecting to logic board
4- SMC needing to be reset
What do u guys think? where do you think is the damage?
Score -1
Add a comment
Most Helpful Answer
logic board analysis showed the chip that controls the power button has burned and was ordered from apple.
Score 1
Add a comment
To start with reset the SMC and PRAM and let us know if it solves your problem. Ralph
http://support.apple.com/kb/HT3964
http://support.apple.com/kb/HT1379
Add a comment
nojan,
How much was that chip? Where is it? On the logic board?
Thanks,
Add a comment
Add your answer
nojan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,016
