Flash problems
Everything works fine. But the flash is not working, even when it's opened manually.
Look with a magnifying glass at the flash tube do you see any cracks or broken pieces of glass? If you do you'll need to get the tube replaced.
If the tube looks OK - Do you hear the flash charging (makes a high pitch squeal) and do you see the ready light lit in the finder? If not the charger circuit is having problems.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 170
