Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Narrow grey bar at bottom of display
A 2-3 mm wide grey bar has appeared at the bottom of the display and is partially obscuring the phone icons. I suspect that the glass has a small crack in it. I have a protective cover on the glass and have not moved it because the phone works fine otherwise.
What needs to be replaced? The complete display assembly or just the front glass?
Score -1
1 Comment
tapioh, it will help if you post an image of this grey bar. It is possible that it is just the glass, but can most certainly be the LCD as well.
by
Add a comment
1 Answer
Most Helpful Answer
LCD Display is damaged. You need to replace LCD Display for iPhone 3GS. Before opening and during any repair of iPhone 3GS make sure the iPhone is OFF.
Score 1
Add a comment
Add your answer
tapioh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 365
