Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Some keyboard keys no longer functioning!
Hi everyone,
My MBP was involved in a slight liquid spill.
Every other component works perfectly except for the keyboard. Certain keys do not work anymore.
I have seen a similar issue on old computers that I have restored: specifically ones with ribbon connectors. Usually cleaning the contact pads or ribbon helps a lot.
How do I remove the keyboard from the case in order to survey it?
Thanks
Dan
Score -1
Add a comment
Chosen Solution
Sadly the keyboard is integrated with the upper case. This is the guide for getting the upper case off.
Score 1
1 Comment:
Thanks for your response! My advice to anyone else is thus "don't spill liquids onto your MBP"!
Dan
by
Add a comment
Follow the guide. Then clean your logic board and keyboard with 95-99% isoporpyl alcohol using a soft toothbrush. Then let it dry for at least 24hrs.
Ground yourself and please disconnect the battery (see the guide) before you mess around in there.
Score 1
1 Comment:
Thanks for that tip atenyim, it's not like it can get any worse! I'll give it a go.
Dan.
by
Add a comment
Add your answer
Daniel Dunn will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 445
