Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Questions View all
Adding Ram with different capacities
The last three figures of my serial number is 9VV. I bought the base model of Mac Mini with 2x2GB ram. I plan to upgrade and replace one of the 2GB with a 8GB ram. I read in one of the support answers that "RAM should be installed in pairs or the machine will suffer true performance set backs." Does this mean they should be of the same capacity as well? Will it affect the performance if I use a 8GB ram in one slot and a 2GB ram in the other?
Add a comment
1 Answer
Most Helpful Answer
9VV didn't bring a machine up. If you have the 2012 model it uses RAM Type: PC3-12800 DDR3 Min. RAM Speed: 1600 MHz
Traditionally you gain what called interleaving with two identical chips giving about a 10% gain. Put the 8 GB chip in the A slot. Unless you are doing really intensive tasks such as PhotoShop rendering, your machine will never go past the first chip. Use a program like Hardware Monitor to see just how much of a load you are putting on your machine and then determine if the RAM you have is sufficient or maybe just a 4 GB chip would suffice.
http://www.bresink.com/osx/HardwareMonit...
Score 3
3 Comments:
Thanks. I have been using the Eclipse IDE and flash player which causes the overall ram usage, including other applications , to over 4gb. I will try the hardware monitor and estimate how much I would need. But I gather from your answer that adding a 8gb and 2 gb ram shouldn't be a problem and I will only lose out on the 10% gain.
by
Which is slot A? The one closest to the board, or the one higher up?
by
The one you install into first (next to the board).
by
Add a comment
Add your answer
Sabman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,185
