0
Score
Avatar
mike
Asked
What is error 3194 on iPhone 4?
History
tried to reset unlocked iphone 4 to factory setting and phone froze and gave error 3194.
Edited by: mike ( )
Post Answer
0
Score
Avatar
oldturkey03
144.7k
Answered
PermalinkHistory
mike, try this:"Error 3194 seems to be triggered when unsigned firmware is used, often during an iOS downgrade or even during some restores. Here’s how to resolve the error:
Fix Error 3194
The fix is the same regardless of what operating system you are using:
Quit iTunes
Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts
Open the hosts file with Administrator privileges
Add the following lines to the very bottom of the hosts file:
74.208.105.171 gs.apple.com
Connect your iPhone to the computer
Launch iTunes
Put the iPhone/iPad/iPod into DFU mode by turning the phone off and then holding down the sleep and power button for 10 seconds, then release the power button but hold onto the home button until iTunes tells you that the device is now in recover mode
Use the iTunes Restore feature as usual with the iOS device
Once your iOS update is finished, remove the “74.208.105.171 gs.apple.com” line from your hosts file again so that iTunes can properly update as usual." from here. Also, if you are using Windows, disabled the firewall. hope this helps, good luck.
Also make sure you are using current iTunes.
Brad,
0
Score
Avatar
reha
145
Answered
PermalinkHistory
Hello! you can go to this link to resolve problem. Hope this will help you out.
http://support.apple.com/kb/TS4451
0
Score
Avatar
Stanyy
Answered
PermalinkHistory
Pretty much what OldTurkey said, but if you need more info, there's a long detailed article on this iPhone error at http://www.easynaija.com/iphone/how-to-f...
0
Score
Avatar
ck79
Answered
PermalinkHistory
If failed again, you can download new firmware from others website and use i-tunes to load again. Remember try other firmware or download again.
0
Score
Avatar
Yuvraj
Answered
PermalinkHistory
Hey guys,
You can check out this blog post on how to resolve the 3194 issue.
http://dressmyphone.in/blog/solving-ipho...
PS: I wrote the guide and have tried to make it as explanatory as I can. If you have any suggestions then let me know.
0
Score
Avatar
jessica2332
31
Answered
PermalinkHistory
It means that there is a problem with the current firmware of the phone. Here are a couple of ways to fix it http://howtofixstuff.blogspot.ca/2012/01...
0
Score
Avatar
arnold falker
Answered
PermalinkHistory
me too was hit by the 3194 error on my iPhone 5 but the Hosts file solution didn't work, in my case it was the Comodo firewall on my computer that was causing the issue. I uninstalled it and the problem was solved ! I found the tutorial on hubpages to be effective most of other tutorial including the one from Apple forum were talking about this Hosts issue only without thinking that it is affected to jailbroken devices only.
Edited by: arnold falker ( )
Add Your Answer
Today: 44
This Week: 423
This Month: 1,035
All Time: 46,177
