2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
Is the SSD disk the same in MacBook Pro 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
Score -1
Add a comment
Chosen Solution
OWC makes a Envoy drive which you can put your stick in an read it via USB. They make a couple of different ones for the different sticks so check before buying. You can then transfer your data and use the old stick for storage. I think this is the one you need: http://eshop.macsales.com/item/OWC/MAU3E...
Score 2
Add a comment
After reviewing the applicable teardowns, I see no reason why you couldn't swap drives. That being said, the 15" comes with twice the storage, so I'd recommend just transferring said data to your new Mac.
Cheers!
Add a comment
Add your answer
Mikkel Christiansen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 479
