Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4 sound not working
Hi
My sound has gone off from my iPhone 4. The ringer works but no sound from music, app, YouTube or anything like this. When I first unlock my phone the sounds for a few seconds and then the volume bar will disappear again.
I have tried restoring my phone and cleaning it with a tooth brush at the dock connector, and also plugging the headphones in and unplugging them as the phones sound works fine with headphones or in a dock.
Thanks
Score -1
Add a comment
Chosen Solution
Clean dock port again with Isopropyl Alcohol. Attach USB cable to iPhone, does this help? Consider replacing dock assembly with flex cable.
2 Comments:
Brad is correct 100 percent !
by
Thanks ill try that, what is a flex cable?
by
Add a comment
Your speaker may be blown. The amount for a ringtone to use is very little. The Music or things of that nature put large wear and tear on your speaker!
Add a comment
Here is a link to the part you might need, a flex cable is like wiring inside your phone, you will see it in this link, http://www.ifixit.com/iPhone-Parts/iPhon..., good luck.
Add a comment
Add your answer
Laurie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 27,850
