Creation of K-Lock Hole
I was thinking about drilling out a K-Lock hole in my iPad Mini. Is there a spot that would be suitable for this? i.e. Is there a spot with enough space behind it to insert a K-Lock?
Have you looked at this solution from Kensington: Security Slot Adapter Kit for Ultrabook or this one Kensington Security Slot Adapter Kit
Here's the spec for the slot Slot Spec
The only problem I see is the thickness of the body may not be thick enough to cut you own.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 401
