Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Possible to install a Retina Display on an Early 2011 unibody MacBook?
My early 2011 unibody Macbook pro 15" LCD broke.
While I am now researching how to fix it by myself, it came to my mind: is it possible to install a Retina Display on it?
What would make it possible? And what wouldn't?
Many thanks!
Score 2
Add a comment
1 Answer
Chosen Solution
Unfortunately, the simple answer is no. The graphics card would have issues running the display if you were even able to instal it. The Retina display MacBook Pro also has different connectors and dimensions then the regular Macbook Pro and therefore not fit and not connect. The firmware for you computer will also not scale the resolution and render properly so you would have a 1440 x 900 resolution displaying on a 2880 x 1800 display which would only take up 1/4 of the display. I wish it were possible but it just isn't. You will have to replace it with a regular 15" 2011 panel.
Hope this Helps
Score 2
2 Comments:
and what about replacing it with display with slightly more pixels (1600x900, i guess) with anti-glare layer? does it fix and how difficult this operation is
by
personally wouldn't risk it I saw someone plug in a wrong screen into MacBook pro heard a fizzle and a pop and both logic board and lcd cables were damaged never had video though lcd again had to run on external screen all the time after that
by
Add a comment
Add your answer
marcelpace will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 21
All Time: 9,486
