Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
How do I replace the light in my iPhone 3GS
When i was out biked i lost my iPhone in a pothole i have cleaned it and everything work except the ligt in the iPhone, i can`t se anything on the iphone but everything else works. So my question is how to replace the light in the iPhone so i can use it again.
Score -1
Add a comment
1 Answer
Chosen Solution
Lars, in order to get your light to work again, there are a few possibilities. The first one, and that is where I would start with, is to disassemble your iPhone. Take a look at all the connectors and make sure that the cables are properly seated. If they are, you may have to change the LCD, since that is the part that lights up. If by any chance it still does not work, you may need a new backlight coil (or a backlight IC) which is soldered onto the logic board. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Lars will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 474
