Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Bizzare Display malfunction, can anyone help please?
Hello, so a few days ago, my Macbook 2009 Unibody 2ghz started doing this (I posted a Video of it on youtube):
http://www.youtube.com/watch?v=FJgwxOkRU...
The macbook boots fine, works fine, even the display, until i start flipping the lid. As soon as there is a minor movement, the screen starts to fade. At the next startup, everything is fine again.
Can anyone help me, or tell me how i could fix this? (I know how to dissasemble the display ;))
Thanks for your help, I really appreciate.
Score -1
Add a comment
Chosen Solution
It must be something with the display cable, look at step 8 on the guide:
MacBook Pro 13" Unibody Mid 2009 Display Replacement
Something similar happened to me with a dell, the data cable had an issue and it would make the display go crazy in colours.
Score 1
Add a comment
I agree.
Typical of a broken video cable in the hinge.
You can see the artifact column on the left as you are touching it and then the signal is inverted once you push it farther back.
Question is if one can order & replace the cable itself, without the screen? As the assembly is $$$.
Add a comment
Add your answer
Thierryl will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 9
All Time: 269
