2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
MacBook wont turn on with the built-in keyboard,turns off immediately
Hello,
first sorry for my english,
when i start my MacBook mid 2010 white unibody it turns off immediately. I tried several things than I found this:
MacBook wont turn on, will display green adapter light/orange charging
So I disconnect the built-in keyboard and "jumped" the two contacts on the logic board and it starts without problems. When I connect the keyboard again, the Macbook turns off immediately.
Now it works with a wireless keyboard but if it turns off for some reason i have to open it and do the same procedure again.
What do you think?
Thanks for any help.
Score -1
Add a comment
1 Answer
Chosen Solution
See if your power button is depressed. This sounds like a liquid damage short. Replacing the upper case should solve the issue: MacBook Unibody (A1342) Upper Case
But you might want to play with the power on button to see if it's not trapped in the ON position and getting constantly pressed.
MacBook Unibody (A1342) Upper Case Image
Product
$179.99
Score 3
1 Comment:
Thanks I will check that.
by
Add a comment
Add your answer
Stan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 883
