Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Questions View all
display problem: half-size screen after installing OS 9
My problem is almost exactly like one mentioned in a discussion thread on "discussions dot apple dot com" that didn't lead to a resolution! Upon startup, the OS 9 screen fills the monitor screen entirely, then halfway thru startup, collapses to about half the screen. The monitor settings only give 1024 x 768, but clicking on on the monitor icon in the bottom scroll gives "color lcd (1) •1024 x 768; display (2) 640 x 480. I don't see any way of changing any settings. Any ideas? Thank you very much.
-Ed
Score -1
2 Comments
Does the problem persist when connected to an external display?
by
I don't have one at home, but you just reminded me that there's one at work I can try. I read that it might be that it might be the wrong version of OS 9 that's causing it, so I'm going to try customer support from the store I bought it from. thanks.
by
Add a comment
Chosen Solution
Try going under the Apple in the upper left hand corner to Control Panels - Monitors. See if this is different than the monitor control you are using.
Score 3
5 Comments:
Start up from your installation CD by holding down the "C" key. If this is a software problem the screen will be normal. If not then you have a hardware pro
by
Perhaps something? The OS 9 "APPle system profiler" shows the PCI--slot ATI (AGP)--> display card--> display (2) as 640x480...additional information: main screen. ???
by
As a general rule the eMac software will install on just about any machine. It appears this is not the case on your machine. You can call Apple 1-800-SOS APPLE and request that they sell you the original installation disks for your machine. They usually charge $15 for this. I don't know which system that would be. But you can then install a upgrade to that system.
by
I was able to test it with a an external monitor. With a Dell flatscreen plugged in, the iMac's screen is still condensed, but the external flatscreen monitor gets the proper display, filling the screen entirely.
by
I spoke with a tech at AllMac and he suspects there might be a short within the external monitor circuit. Because it's showing a 2nd monitor in the monitor info on the bottom tool bar when one is not plugged in, he thinks that the short could be making the computer erroneously detect a non-VESA-compliant monitor in the port, which is defaulted to 640x480, so it's mirroring that non-existent monitor by displaying 640 x480 over the 1024 x7xx screen. He suggested I try reseting the p-ram, holding Apple-Option-P-R as it chimes three times during start-up, but that didn't help.
Does this sound right to anyone, that the monitor port is shorted or some other hardware issue? I have 2 days to return this, and though I'd actually like to keep it if I can get the full screen going, it's not worth the labor rate to resolve a hardware issue.
anyway, thanks to all.
-Ed
by
Add a comment
If half your LCD is not shot
(I'm not sure I'm understanding "collapses to about half the screen" ) you might try this handy app. It allows choosing odd resolutions.
Good Luck,
N.
2 Comments:
The screen is fine. It's some software issue I'm presuming. It starts off showing the startup screen filling the entire screen. At some point the image concentrates itself into a rectangle centered on the screen with about a 3'' black border. If I were to guess, I'd say it's showing a 640x480 image over a 1024x768 screen. I looked at those apps. One looks like it could be related to screen settings but I don't know how to apply it. Thanks, though, I'll explore it a bit further.
-Ed
by
OS 10.2 displays fine. Might be a compatibility issue with the particular 9.2 software, or perhaps an update needed? Unfortunately I can't get on line with it yet.
by
Add a comment
The ATI Driver update is old. What you need is version 2.4.4. I just did this and fixed the problem. Put it in the extensions folder
1 Comment:
Where did you get the ATI Driver Update version 2.4.4? I'm having the same problem as Ed and can't seem to find that version of the extension online.
by
Add a comment
Add your answer
Ed Hudecek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,139
