Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Replaced battery, no charge, no reception, no wifi
So I just replaced my dying battery with a new one only to notice it wouldn't keep a charge (works only when connected to power outlet and shuts down when disconnected).
There's no service or wifi as well.
I double checked and tested all the connections and when I replace the new battery with my old one (which still has some juice left) everything works fine.
So I'm quite sure this isn't a connection problem.
But what is it? Is it the new battery not working correctly?
I was expecting this to be easier and more troublefree than it is now.
Thank you for your help.
Add a comment
1 Answer
Have you found out anything else? Did you resolve your issue?
I just replaced the battery in a 3gs ... most cautiously without doing any visible damage under magnification.
Fully assembled:
- not charging
- doesn't respond to power button
- no wifi???
Redid all the steps. Same.
Update
I'm still waiting on new exchange battery. Phone has been fine on original battery.
1 Comment:
To update.
I opened the phone back up for the third time, inspected everything under magnification (no damage, dust, ... whatsoever) and put the original battery back in.
- power button works
- wifi is on and usable
- it charges
So must have received a bum battery ?
Or a battery with some bum little circuit board on it?
by
Add a comment
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 14
All Time: 621
