Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Question Closed
upgraded CPU and now no power
So I took the plunge and upgraded the CPU from 2.0Ghz core duo to 2.16ghz core 2 duo. Now I have no power and all that happens when I hit the power button is the light blinks once, shuts off and nothing happens. I have reseated the memory many time and I have even completely taken it apart and tried a second CPU of the same specs and still get the same issues.
Does anyone have a clue what could be the issue?
My last resort would be to take it apart again and put the old CPU back in to see if it boots and I didn't fry the board at some point.
I was really careful and even cleaned every thing out with a compressor because the thing was disgusting with dust build up.
Any help before I take a 3rd plunge would be appreciated.
1 Comment
So I may have figured out my problem. I am using a t5850 processor 2.16ghz. It fits in the socket with no issues but it may not be compatible.
Can someone please confirm this that may have tried the upgrade?
thanks again,
by
Add a comment
Chosen Solution
AFAIK you have to "upgrade" to a CPU used or "offered" by Apple... the EFI firmware won't support anything else. See this previous Question and Answers.
If this answer was helpful please remember to return and mark it Accepted.
1 Comment:
This didn't really help but thanks for trying.
by
Add a comment
Most Helpful Answer
Run through my answer here and see if it helps: Core Duo CPU upgrade to Core 2 Duo CPU?
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 715
