Student In Progress
This wiki is being worked on by hardworking students.
Anbernic RG28XX Audio Distortion
Audio crackling, static interference, or missing sound all together. The issues could be simply dust in the speaker, a physically defective speaker, or an issue with the motherboard.
Dust
There could be dust that is distorting the audio quality by not allowing the speaker to vibrate properly and produce sound waves. To fix this issue, simply blow into the speaker slits on the front of the device.
Dirty Speaker
Another way of solving audio issues is to clean off the speaker itself, which requires taking the device apart.
1) Power down and open the case - Turn the device all the way off, remove the four hex screws on the back, and use a plastic pry tool to carefully open the device.
2) Clean speaker/speaker area - Locate the small round speaker at the bottom ("chin") of the motherboard. Check for dust, metal fillings, or debris. Either use a dry cloth to wipe off or use a blast of compressed air to clean out.
3) Ensure the speaker is firm - If the speaker is loose then it will vibrate against the shell at high volumes, disrupting audio quality.
Faulty Speaker
To replace the speaker, you will have to disassemble the casing for the device to access the speaker.
1) Remove rear screws and rear case - Using a TR6 Hex Bit, remove the 4 screws holding the device together. Next, use a plastic pry tool along the seam between the front and rear case of the device and apply light pressure until they pop apart. After an opening is created, you will need to drag the pry tool along the edge to open the remaining connections to the case.
2) Carefully remove speaker connector - The speaker is a black disc shaped piece inside the device next to the motherboard and is connected to a white connector that is square in shape with a red and a black wire. To remove the speaker, gently pull the white connector apart from the receiving connector on the motherboard. Be careful not to pull on the connector on the motherboard as it is also white and removing it would cause a permanent loss in audio.
3) Replace speaker - With the replacement speaker in hand, gently push the connector into the receiving connector the previous defective speaker sat in and place it inside its housing cutout and put the case back together. One thing to note, the buttons very often jump out of their place whenever you are disassembling the case, so make sure they are all back in place before putting the device back together.
Defective Hardware
After the previous fixes and the problem persists, there is a possibility of loose or failing internal components or other firmware issues. These problems can be diagnosed and fixed through systematic checks and hardware replacement if needed. Check if the device is updated to its current version or test different apps to see if it is related to that specific game. If not, inspect for internal damage such as damaged connections or wiring damage. Replacement of the motherboard or the device entirely could be necessary at this point.
Author
with
Kaitlyn M
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 36
All Time: 36
