Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
>>Screen won’t turn on<<
the phone will not power on, even when plugged into the charger.
Died battery
If you are having trouble with powering up the device and have tried plugging into the charger and still receive no screen response and no green light, This problem can possibly be your battery. consider making an appointment to have the battery replaced. You can also try a step by step guide on how to replace the battery. [coming soon].
faulty charging port/ dirty port
checking charging port for any dirt and clean out carefully can seem very simple, but this can be the root of your problem. A dirty port can cause your device not to receive any charge making it look as your battery is to blame. try using a gentle brush to clean your charging port.
>>Hard to hear during calls <<
People on the other end of a phone call can’t understand a word I am saying, distorted and muffled sound From another end.
Faulty microphone
The problem can very possibly be a defective microphone if you are experiencing a muffled sound, distorted noise. Check for a warranty on the device. You can order a replacement microphone and follow a step by step guide [coming soon] or check the warranty on your device.
Cellular problems
Many times being far from mobile towers can make it hard for the person on the other end to hear you, muffled sound, or a call can cut off can be a cellular issue. Simply by being far from mobile towers can give you a poor connection and providing your poor cellular connection. Check your cellular service provider and make sure you are near cellular towers to experience excellent cellular service. Try checking which cellular service provider covers your county or town to get the best service.
>> Frozen, blank or black screen <<
When trying to boot up the device, the device displays a blank screen or black screen but vibrates.
Dirty built up under the screen
If you are experiencing a blank screen or an unresponsive screen, the problem may be dirt, dirt can build up underneath a screen. Taking off the screen and cleaning dirt and rebooting the device and performing a soft reset can fix this. To soft reset it, you first must Press and hold the Power and Volume Up buttons (located on the top and left edge of the device) until the device powers on/off (can take up to 2 minutes).
Brightness might be low
A black screen can be mistaken for a bad screen, but first, try your brightness settings. Many of the times if you feel your phone vibrating and you see a black screen you should try to go into a dark room and upon unlocking the phone, go to settings, then display, select brightness and increase to personal taste.
>>Device won’t charge<<
The phone is turned on, but when connected to the charger, it won’t charge.
When trying to charge a device and it won’t cost the charging port, maybe to blame, it might either be dirty or damaged. When faulty, you can check the warranty and have manufacture to replace the port. Try cleaning port with little brush and carefully clean and then try plugging in the charger.
Faulty charger
If you keep trying to charge your device with the same charger, but you see no response, a faulty charger can also be the problem, not having a properly working charger will not work causing you to believe it is your phone. Try using a charger that is known to work and plug into an outlet.
faulty wall outlet
If the charger is not the problem, try using a different outlet that is known to work. The last option that many times is overseen can very well be the power outlet.
>>Phone Battery losses charge quickly<<
My phone is completely charged and after using it for shot period of time my phone displays a low charge.
To many background applications
If you are experiencing slow and very sluggish performance and rapid battery lose, applications can run in the background that you may not know about. This may happen when you press the home button when leaving an application But not fully exiting out, making your device work harder. to fix this you must first press on the button next to your home button shaped like a window, after that you will see all recent applications you have visited, now press on the “X” to exit out of any unwanted apps.
If, when trying to charge your phone, it seems to work when you twist the charger a certain way but works fine when used on a different device, your port may be the problem. Over time When using a faulty charger or an incompatible charger it can put a toll on your device. A mismatched charger not using the right voltage, amps, or plug type as the original can make your phone charging port to be faulty and giving the incorrect charge the battery and reducing your batteries health. To solve this problem first, replacing the charging port by following these step [charging port replacement guide coming soon] once that is successful use a charger compatible with your device, this is done by checking the device manufacture handbook.
Faulty battery
most of the time, when you are experiencing battery loss rapidly, this can be due to low battery health, you may experience low performance, unexpected drop in battery percentage and also slow charging. By following our step by step guide on how to replace a battery, this can be solved quickly [coming soon]. You may also refer to manufacture for battery specifications.
0 Comments
