Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Won't Turn On
You can't seem to get your tablet to turn on.
Power Button is Not Working
Is the power key stuck and unable to be pressed? If so please fallow the sticky key repair guide.
Drained/Bad Battery
If your device will not turn on, a replacement battery may need to be purchased.
Please follow the replacement battery guide.
Bad Display
It is possible that it appears nothing is happening because the display is bad. If it is possible that the display is bad and must be replaced.
Cracked or Broken Screen
' ' Is your screen cracked or broken ' '
If your screen is cracked or broken you will need to buy a replacement screen and follow the screen repair or replacement guide.
Sticky or Broken Buttons
' ' Are the Buttons on your device sticky or simply won't work ' '
Sticky Buttons
If the buttons on your device are sticky you may need to replace them or just clean around the button. Please fallow the repair or replace buttons guide.
Broken Buttons
If the button on your device simply will not work it is most likely because the button has been broken or disconnected on the inside of the device. Please follow the repair or replace buttons guide.
Sound Problems
' ' Does the sound on your device not work? ' '
Speaker Problems
If the speaker on your device is not working you may need to buy a replacement speaker. Please follow the repair or replace speaker guide.
Headphone Problems
If your headphones do not work with this device, first make sure that your headphones are working by testing them on another device.
If you find that your headphones do not work with the tablet it is most likely because the headphone port on the device is bad. You will most likely need to purchase a replacement port. Please fallow the replace or repair port guide.
Broken Portholes
' ' Is one of your portholes on your device not working ' '
If one or more of your portholes are broken on your device you may need to buy a replacement porthole. Please follow the replace or repair portholes guide.
Daniel Brandt
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 445
