ecoflow field manual
Basic data for the ecoflow delta pro 3600
EcoFlow DELTA Pro 3 (EFD521) — Field Repair Guidebook v4
For the Global Right-to-Repair Community
Revision: v4.0 (2025-10-02)
Applicability: Board revision EFD521-2023Q4 and similar
Language: English
Disclaimer: No OEM schematics. Community-verified procedures marked explicitly. This guide consolidates Russian, Chinese, and English-language repair intelligence for component-level field repair.
Document Revision History
v4.0 (2025-10-02):
- Integrated Russian forum component intelligence (monitor.net.ru, gsm.in.ua)
- Added Chinese teardown data (Chongdiantou.com)
- Documented gate driver and IGBT specifications from field repairs
- Added "plug-plug backfeed" failure mode (primary cause in Ukraine/Russia)
- Included thermal failure thresholds from DELTA Max repair logs
- Added component sourcing information and substitution warnings
- Marked claims as [VERIFIED], [UNVERIFIED], or [NOT FOUND] based on multi-source validation
- Expanded parts list with specific part numbers from repair community
v3.0 (2025-10-02):
- Added thermal abort criteria for deep-discharge recovery
- Clarified cell-level voltage thresholds and scrap criteria
- Enhanced XT60i ID-pin hardware damage warning
- Added VCP failure-mode diagnostics
- Added formal post-repair validation checklist
- Specified hardware/firmware applicability
v2.0 (2025-09-15):
- Clarified PV total limit to 2600W
- Refined VCP headroom criterion (≥8V delta)
- Added P7 probe (AC IN precharge path)
- Expanded parts list and appendices
v1.0 (2025-08-01):
- Initial consolidation from field notes and repair threads
1. Scope & Safety
HIGH ENERGY PRESENT. This unit contains:
- 4096 Wh LFP battery pack at nominal 51.2V (68V max charge)
- 4000W continuous AC inverter
- High-voltage PFC/charger circuits up to 400V DC bus
Mandatory Safety Practices
- Isolation: Use isolation transformer or current-limited bench supply for first power-ups
- PPE: Insulated gloves rated ≥1000V, safety glasses, non-conductive work surface
- Current limiting: Never apply unlimited current to pack terminals or power stages
- Discharge: Verify bulk capacitors discharged (wait 5 minutes after AC disconnect, probe before touching)
- One-hand rule: Keep one hand behind back when probing live circuits where possible
- Never short MOSFETs: Use controlled pre-charge; forced MOSFET shorting risks fire and pack damage
- Thermal monitoring: Have IR thermometer or thermal camera available; abort on unexpected heating
- Ventilation: LFP thermal runaway is rare but produces toxic gases; work in ventilated area
- Fire suppression: Class D extinguisher or dry sand nearby (water on Li-ion fire spreads flames)
- Work with partner: Never perform high-voltage work alone; partner should know emergency shutoff procedures
CRITICAL PROHIBITION
DO NOT force-short BMS FETs to bypass protections. This procedure:
- Bypasses critical low-voltage and over-current protection
- Can cause lithium plating if cells are charged below freezing
- May weld FETs closed, creating uncontrolled charge/discharge path
- Voids any remaining warranty and creates liability for subsequent failures
Use controlled pre-charge per Section 6, Tier 4.
2. Fast Specs & Guardrails
Battery & Chemistry
- Capacity: 4096 Wh (80 Ah nominal)
- Cell type: 40135 cylindrical LiFePO₄ [CN teardown]
- Configuration: 16S LFP, nominal 51.2V
- Voltage range: 40V (deep discharge) to 58.4V (HVP cutoff), 3.65V/cell max
- Safe operating range: 44V (LVP cutoff) to 58.4V (HVP cutoff)
- Cycle life: ~4000 cycles to ≥80% SoH at 0.5C, 25°C [spec]
- Continuous discharge: 80A (~4kW sustained)
- Construction: CTC (Cell-to-Chassis) with IP65 rating [CN analysis]
AC Output
- Continuous power: 4000W
- Surge capability: 8000W [spec]
- Voltage selection: 120V OR 240V (mutually exclusive; switch in app)
- 120V mode: 120V outlets active; 240V outlets disabled
- 240V mode: 240V outlets (L14-30, 6-20R) active; 120V outlets disabled
- Waveform: Pure sine, <3% THD typical
- UPS transfer time: 10ms [spec]
PV Input (Two Ports — TOTAL LIMIT: 2600W)
Both ports may operate concurrently, but combined input must not exceed 2600W total.
- High-voltage PV: 30–150V DC, ≤15A, ≤1600W [XT60 2-pin]
- Low-voltage PV/Car: 11–60V DC, ≤20A, ≤1000W [XT60i 3-pin with ID]
Power limiting mechanism [VERIFIED]: Software-primary with hardware backup. MPPT algorithm continuously adjusts PWM duty cycle to regulate current draw. Hardware provides overcurrent detection, overvoltage protection, reverse polarity protection, and short-circuit shutdown.
AC Charging (Grid)
- Input range: 100–240V AC, 50/60 Hz
- X-Stream fast charging: 2200W max (220-240V @ 20A input) [CN spec]
- US 120V grid: Typically ~2000W max via standard AC IN
- EV X-Stream Adapter: Up to ~4000W at 240V via AC IN/OUT port [spec]
- Combined AC + Solar: 7000W total maximum input [spec]
- Charging time: 0-80% in 50 minutes (AC + solar), 0-100% in ~2.5 hours (AC only)
- App power cap: Adjustable; set conservatively (800–1200W) for small gensets
12V DC Outputs
- Voltage: 12.6V regulated [CN measurement]
- Maximum current: 30A continuous, 378W total capacity [spec]
- Topology: Synchronous buck converter (inferred from efficiency)
- Outputs: CAR post (cigarette lighter), Anderson PowerPole, DC5521 barrel jack
- USB-C: Dual 100W ports (5/9/12/15/20V @ 5A each), 200W combined
- USB-C PPS: 3.3-21V @ 3A programmable power supply mode
- USB-A: 18W each (36W total), QC3.0/FCP/AFC/Apple 2.4A protocols
Extra Battery Expansion
- Capacity: Up to 2 Extra Batteries per main unit (12kWh total for 3-unit system)
- Maximum system: 48kWh with parallel configuration [spec]
- Connector: Proprietary EcoFlow interface
- Protocol: [NOT FOUND] - Pinout and communication protocol undocumented in public sources
- Voltage range: 40-58.4V (matches main pack LiFePO4 16S configuration)
3. XT60i ID-Pin Behavior & Hardware Damage Risk
XT60 vs XT60i
- XT60 (standard): 2-pin power-only connector, 60A continuous rating
- XT60i (EcoFlow/AMASS): 3-pin connector with center ID pin for source identification
ID-Pin Logic
[UNVERIFIED - COMMUNITY REPORTS] Based on field testing by repair community, the Low-PV port (11–60V) behavior:
ID Pin State Reported Behavior Current Limit Input Stage Design ID → GND (−) Solar/high current mode ~20A Robust traces, larger FETs ID → VCC (+) or open Car/weak source mode ~8A typical Lighter traces, smaller FETs
IMPORTANT: This ID-pin behavior is community-reported and not officially documented by EcoFlow. The XT60i connector specification indicates digital communication protocol capability (BattGo smart battery systems), but EcoFlow's specific implementation remains proprietary.
CRITICAL HARDWARE DAMAGE WARNING
Incorrect ID-pin wiring can cause the MPPT controller to attempt high-current solar charging (>15A) through the low-current car-input path (thermally rated for ~8A).
This WILL damage:
- Input-stage MOSFETs (thermal runaway, gate oxide punch-through)
- PCB traces (carbonization, delamination from excessive current density)
- XT60i connector itself (pin/housing melt, contact welding)
Russian repair forum documentation [VERIFIED]: Multiple repair logs on gsm.in.ua confirm MPPT input stage failures correlating with non-genuine XT60i adapters or incorrect ID-pin wiring.
Before using any non-genuine XT60i adapter:
- Verify ID-pin wiring with continuity tester against genuine adapter
- Confirm ID → GND for solar panels; ID → open or VCC for car/alternator sources
- Test initial connection at reduced current (use series blocking diode or current-limited supply)
- Monitor connector temperature for first 10 minutes; abort if >50°C
- If in doubt, use standard XT60 (2-pin) on High-Voltage PV port instead
4. Connector & Probe Ledger
Probe Legend (P1–P7)
All subsequent diagnostics reference these standard probe points:
Probe Description Expected Value Critical for P1 Logic rails: +5V, +3.3V on BMS/control board 5.0V ±5%, 3.3V ±5%; ripple <50mV pk-pk All procedures P2 Charge-pump headroom: VCP vs Vpack VCP = Vpack + 10V typical (PASS if ≥8V delta) Deep discharge recovery P3 PV board: +5V rail, CAN H/L +5V: 5.0V ±5%; CAN idle: ~2.5V each, diff. activity Error 304, 242 P4 AC charger DC output to pack 44–58V during charge; current per app setting AC charging diagnosis P5 Inverter gate drivers, current sensors Gate drive: clean square wave; HLSR50-P: linear with load Error 022, 121 P6 12V domain: TVS, shunt amps, PWM TVS: <0.7V fwd (Si), <0.3V (Schottky); PWM present during enable Error 125 P7 AC IN precharge: fuse, NTC, PFC relay Fuse: <0.5Ω; precharge R: 10–50Ω; relay coil energized when AC present AC charging failures
4.1 A. AC / GRID PATHS
Signal flow: AC IN (Grid) → PFC/Charger → DC bus → Pack
Spec guardrail: 100–240V AC; US 120V grid typically ~2000W max
Components: Precharge NTC thermistor, inlet fuse, PFC relay, boost PFC stage
P7 Quick Checks (AC Path)
- AC inlet fuse continuity: _______ Ω (expect <0.5Ω)
- PFC precharge resistor: _______ Ω (expect 10–50Ω; OL = open/bad, ~0Ω = suspect PFC/bus short)
- PFC relay coil voltage when AC applied: _______ V (relay must pull in for main charger to engage)
[NEW - RU forum component ID]: DELTA family products use ICE3AR1580VJZ PFC controller (position U10) and 210h-2ah1-f-c-12vdc relay for AC output switching (DELTA Max). Pro 3 specific components not yet documented.
Charger DC Output
- Voltage to pack: _______ V @ _______ A
- App charge power cap set to: _______ W (keep 800–1200W on small gensets)
4.2 B. AC OUTPUTS
Mutual exclusivity: 120V mode OR 240V mode (never both simultaneously)
- 120V mode: 120V outlets ON; 240V outlets OFF
- 240V mode: 240V outlets (L14-30, 6-20R) ON; 120V outlets OFF
[VERIFIED - RU repair log]: Relay contact failure (welded closed or failure to close) documented as mechanical weak point after tens of thousands of cycles. AC output fails even when inverter remains functional.
Probes
- Selected mode: 120V / 240V (circle one)
- No-load AC OUT: _______ V RMS
- Inverter idle current draw: _______ A
- THD% (if meter available): _______ % (expect <3%)
4.3 C. PV / DC INPUTS (MPPT Front-End)
Two PV domains (TOTAL ≤ 2600W):
- High-voltage PV: 30–150V, ≤15A, ≤1600W [XT60 2-pin]
- Low-voltage PV/Car: 11–60V, ≤20A, ≤1000W [XT60i 3-pin with ID]
XT60i ID behavior [UNVERIFIED]: ID→(−) ⇒ solar/high current; ID→(+) or open ⇒ car/low current
WARNING: Mis-ID can damage input stage (see Section 3).
[NEW - CN teardown component families]: Related EcoFlow products use Renesas ISL81601 dual-direction buck-boost controllers (60V capable), MC96F1206 MPPT MCUs, and Southchip USB-C PD controllers. Pro 3 specific ICs not yet identified.
Probes
- PV HV open-circuit voltage (Voc): _______ V
- PV HV short-circuit current (Isc): _______ A
- PV LV open-circuit voltage (Voc): _______ V
- PV LV short-circuit current (Isc): _______ A
- MPPT local rails: +12V _____ V, +5V _____ V
- PV board CAN transceiver P/N: _______ ; +5V rail: _______ V
[VERIFIED - RU repair community]: Common CAN transceivers: TJA1052IT (NXP, isolated), SN65HVD230/233 (TI, standard). Replace when +5V rail sags or CAN bus stuck.
4.4 D. 12V DOMAIN
Outputs: CAR high-current post, Anderson PowerPole, DC5521 barrel jack
Common weak points: TVS/suppressor, shunt amplifiers (op-amps), feedback sense lines
[NEW - CN teardown]: RIVER series uses Southchip SC8815 + SC2021A protocol ICs and MPS MP9447 synchronous buck controllers. Pro 3 12V domain components not yet documented.
Probes
- TVS diode: Visual inspection OK? _____ ; Diode test fwd drop: _____ V (Si: ~0.7V, Schottky: ~0.3V)
- CAR 12V under 1–5A load: _______ V (droop should be < 0.5V from no-load)
- Shunt amp outputs: Reference _____ V, Load _____ V
- PWM enable signal present (scope)? Y / N ; Frequency: _______ kHz
4.5 E. EXTRA BATTERY (EB) PORTS
Purpose: Interconnect to Pack/BMS bus (up to 2 Extra Batteries)
Connector: Proprietary; [NOT FOUND] - pinout not publicly documented
Russian/Ukrainian repair community search: No EB port pinout information found on monitor.net.ru, gsm.in.ua, or Chinese forums despite extensive search (Oct 2025). This represents significant documentation gap.
Probes
- EB cable integrity (continuity each pin): OK? Y / N
- EB detected in app? Y / N ; SOC delta from main pack: ≤ _______ %
- Fault clears when EB disconnected? Y / N
4.6 F. BMS / CONTROL BOARD
[NEW - Component intelligence from RU/CN sources]:
Likely IC families (based on DELTA product line analysis):
- MCU: GD32F10x ARM Cortex-M3 series (GigaDevice) [RU repair logs document MR300-BMS-V1 boards]
- Battery monitor: TI BQ76952 (3S-16S, matches 16S application) [high confidence based on specifications]
- High-side FET driver: TI BQ76200 or equivalent [specification match]
- Fuel gauge: BQ34110 (documented in RIVER series) [CN teardown]
Pro 3 specific IC models [UNVERIFIED]: Visual confirmation awaits teardown documentation.
Power Rails
- +5V: _____ V (ripple OK? Y / N)
- +3.3V: _____ V (ripple OK? Y / N)
Charge-Pump Headroom (CRITICAL)
- Vpack (pack voltage): _______ V
- VCP (charge-pump output): _______ V
- Headroom (VCP − Vpack): _______ V
Criterion: VCP ≈ Vpack + 10V
PASS if: VCP − Vpack ≥ 8V
FAIL if: VCP − Vpack < 8V or VCP ≈ Vpack
[VERIFIED - TI BQ76952 datasheet analysis]: The 8V specification is CONSERVATIVE, not absolute minimum. BQ76952 charge-pump specifications:
- VBAT ≥ 8V: CHG/DSG FET drivers output 10-13V (typical 11V)
- 4.7V ≤ VBAT < 8V: CHG/DSG FET drivers output 8-13V (typical 11V)
- Typical MOSFET Vgs(threshold): 2-4V
- Recommended Vgs for saturation: 10V
The 8V criterion provides margin for temperature variations (-20°C to 60°C), component tolerances (±20% on capacitors), aging effects, and transient voltage drops during switching.
Failure modes:
- VCP = Vpack (no boost): Charge-pump oscillator dead, boost diode open, boost capacitor failed, or EN pin not asserted
- VCP < Vpack + 8V but > Vpack: Insufficient charge-pump frequency (check oscillator components), lossy boost path, or marginal supply voltage to driver IC
Consequence of failure: High-side FETs cannot turn on cleanly; BMS will latch into protection mode or exhibit intermittent connection.
Thermistors & Current Sense
- NTC harness seated? Y / N ; Any opens/shorts detected? _______
- Shunt voltage at _____ A load: _______ mV
[NEW - RU repair documentation]: 390Ω 5W shunt resistors serve as current sense elements throughout power stages. Cell balancing operates via passive methods with cell voltage spread under 0.1V considered healthy.
4.7 G. INVERTER SUBMODULE
[NEW - MAJOR UPDATE: Russian repair forum component documentation]
Three-Stage Architecture
Stage 1: Primary DC-DC Converter (48V battery → 400V DC rail)
- IGBTs in half-bridge or full-bridge configuration
- Isolated gate drivers provide galvanic isolation
- Handles peak power transfer from battery
Stage 2: Inverter (400V DC → 120/240V AC)
- IGBT-based H-bridge topology
- Dedicated isolated gate drivers per switching position
- Output LC filtering for pure sine wave generation
- Current sensing via low-ohm shunt resistors
Stage 3: Synchronous Rectifier (AC charging path)
- High-voltage N-channel MOSFETs
- Bidirectional power flow for AC charging
- Separate gate driver circuits
400V intermediate DC bus confirmed in multiple Russian repair logs measuring bus voltage during troubleshooting.
Gate Driver Components [VERIFIED - RU repair logs]
NSI6602A-DSWR (SOW16 package) - Extensively documented in Ukrainian repair forum:
- Application: EcoFlow DELTA and DELTA Max 2000
- Type: Isolated half-bridge gate driver
- Output current: 4A sink/source
- Features: Adjustable dead time via single resistor
- Direct equivalents: UCC21520 (TI), ADuM4221 (Analog Devices)
- Alternative designation: SIS6201 (possibly alternate marking)
- Power requirements: Dual rails - 5V logic, 15V gate drive output
- Support ICs: 7815 (15V reg), 7805 (5V reg), 1117-3.3V (logic)
- Ukraine pricing (2023): Initially 800-1000 UAH, dropped to 120-250 UAH by March
CRITICAL REPAIR NOTE [RU community]: "Replace ALL gate drivers in affected converter stage, not selectively." Technician reports units that failed again within one week when only visibly-failed drivers replaced. Stable operation achieved only after replacing all drivers in the section.
Power Semiconductor Components [VERIFIED - RU repair logs with part numbers]
For EcoFlow DELTA:
- G40T60AN3H / CRG40T60AN3H (K3H suffix variants exist)
- 40A continuous (80A peak), 600V, 280W dissipation
- Vce(sat): 1.9V, Input capacitance: 3400pF
For EcoFlow DELTA Max 2000:
- G60T60AN3H / CRG60T60AN3H (K3H suffix variants exist)
- 60A continuous (120A peak), 600V, 403W dissipation
- Vce(sat): 1.85V, Input capacitance: 3400pF
- Price: ~450 UAH (Ukraine, 2023)
- Documented working replacement: IRGP35B60PDPBF (160 UAH, significantly cheaper)
Additional documented options:
- G75T60AK3HD (500 UAH)
- SRC60R140B TO-220F 650V 30A (350 UAH)
- G15T60A83L TO-220F IGBT (350 UAH)
Synchronous Rectifier MOSFETs:
- CRJQ190N65: High-voltage N-channel MOSFET (positions Q9, Q15, Q11, Q16 in DELTA Max)
[CRITICAL WARNING - RU repair community consensus]: "На экофло нужно ставить только те транзисторы которые стоят там" (For EcoFlow, you must use only the exact transistor models originally installed).
Technicians report aftermarket IGBT substitutes cause premature failures even when ratings match or exceed originals. This suggests proprietary gate charge characteristics or switching speed requirements not captured in standard datasheet parameters. Use exact OEM part numbers whenever possible.
Gate Protection and Support Components [RU repair log]
Protection topology documented from gsm.in.ua repair thread:
- SOD package diode between gate and emitter (TVS or Zener function)
- SMD marking: "ow" with horizontal "7"
- Parallel resistor: 47kΩ gate-emitter pulldown
- Purpose: Gate voltage clamping and ESD protection
- Survival rate: High (typically intact during IGBT failures)
Current sense network:
- 390Ω 5W primary current shunt resistors
- 68Ω, 20Ω, 4.7Ω resistors in IGBT active circuitry
- Fast recovery diodes: US1M, 1N4148W
Support components typically survive when IGBTs fail, suggesting overstress rather than support circuit failure as root cause.
Probes
- Submodule 5V idle draw: _______ mA (typical: 80-100mA; >150mA may indicate fault)
- Heat map anomalies (IR cam) near gate driver sites? _______
- Gate driver waveforms clean (scope)? Y / N ; Rise/fall time: _______ ns
- LEM HLSR50-P current sensor outputs at X A load: _______ V (should scale linearly)
[NEW - Reported parts from repair threads]:
- TP181 (×1) - Likely gate driver or controller IC [UNVERIFIED - Pro 3 designation]
- TP2412 (×6) - Likely MOSFET gate drivers or PWM controllers [UNVERIFIED - Pro 3 designation]
- LEM HLSR50-P (×2) - Isolated current sensors on main inverter board [VERIFIED]
4.8 H. COMMS / FIRMWARE
Common error codes and subsystems:
Error Subsystem Diagnostic Focus Status 022 BMS/Protection & Inverter Backfeed or deep-discharge; check inverter devices/drivers [VERIFIED] 121 Inverter power stage Overload/short; validate repairs under light load [VERIFIED] 304 PV/DC board comms CAN transceiver, +5V rail [VERIFIED] 242 Firmware update path Fix comms first; retry on strong Wi-Fi (alternate AP/VPN) [NOT FOUND - no detailed documentation] 125 12V domain TVS event; inspect suppressors, shunt amps, feedback [NOT FOUND - no detailed documentation] 305 USB port protection USB1 short circuit (community/official replies) [VERIFIED]
Probes
- CAN H/L at PV board (idle): _____ / _____ V (expect ~2.5V each)
- CAN transceiver replaced? Y / N ; Part#: _______ ; Result: _______
- App firmware update result: _______
5. Inverter Stage Thermal Management
Thermal Performance and Throttling
[NEW - Critical thermal data from Russian repair logs]
DELTA Max 2000 thermal imaging analysis (gsm.in.ua):
- Up to 700W: Normal operation, moderate temperatures
- 1000W+: Primary converter transistors (48V→400V stage) reach 130°C within minutes
- Other inverter stages: 40-60°C (normal range)
- Thermal shutdown: Triggered after several minutes at 130°C
- Fan behavior: Operate at maximum speed before shutdown (functional but insufficient cooling in older model)
The technician notes: "Primary stage transistors heat to 130°C within minutes. Common heatsink makes individual measurement difficult. Thermal camera shows all transistors heating to similar temperature."
DELTA Pro 3 thermal design improvements [CN analysis]:
- X-Quiet 3.0 technology with stepless fan control
- Wind tunnel airflow design with dynamic adjustment
- Measured noise: 30 dB under 2000W load (library-quiet level)
- Exhaust temperature: 37.5°C at 2000W output (25°C ambient)
- Intelligent temperature monitoring across power stages
[UNVERIFIED] Specific thermal throttling thresholds (temperature setpoints for power reduction) remain undocumented for DELTA Pro 3. The 130°C measurement from DELTA Max suggests this may be near the shutdown threshold for older models, but improved cooling in Pro 3 likely changes this behavior.
Thermal Monitoring During Repair
Acceptance criteria after power stage repairs:
- MOSFET/IGBT case temperatures should remain <70°C at 20% rated load (800W)
- Any component exceeding 80°C at light load indicates problem
- Primary stage should not exceed 90°C at 50% load (2000W) with proper airflow
- Use IR thermometer or thermal camera to verify even heating across parallel devices
6. Deep-Discharge Recovery Checklist (Tiered)
SCOPE & ASSUMPTIONS
- Device: EcoFlow DELTA Pro 3 (EFD521) and close relatives
- State: Unit disassembled or partially torn down; pack voltage abnormally low
- Goal: Safely wake a deep-discharged pack and restore normal BMS control without force-shorting MOSFETs
[NEW - RU/CN repair community consensus]: Deep discharge lockout is most common failure mode in stored or rarely-used units. BMS enters protection mode when cells drop below 2.5V/cell. Gate drivers cannot activate due to insufficient bootstrap voltage.
SAFETY BASELINES
- Treat pack as LIVE at all times; discharge capacitors before probing
- Use current limiter on first power-ups
- Never "hard short" MOSFETs — use controlled pre-charge
- Keep one hand behind back when probing live circuits
- Reinstall shields/insulators before any full-power test
- Work with a partner - never perform high-voltage procedures alone
Tier 0 — VISUAL & MECHANICAL
[NEW - RU repair forum pre-inspection protocol]:
☐ Clean board with isopropyl alcohol to remove flux residue
☐ Inspect for "hair" strands of wire between SMD pads (extremely common per RU forums)
☐ Check for solder bridges on high-density areas
☐ Verify all PCB traces intact (use multimeter continuity mode)
☐ Look for discolored components or board areas indicating thermal damage
☐ Confirm all board standoffs present
☐ Replace missing screws:
- M3: _____ count, torque ~0.5–0.6 N·m, light threadlocker
- M4: _____ count, torque ~1.2–1.8 N·m, light threadlocker
☐ Check for pinched NTC thermistor harnesses
☐ Check for half-seated board-to-board connectors
☐ Verify fans spin freely; clear dust from ducts
☐ Reseat Extra Battery (EB) and PV cables if installed
Tier 1 — ISOLATE & BASELINE RESISTANCE
☐ Disconnect all external connections: AC OUT, AC IN, PV, EB, 12V outputs
☐ Work only with base unit on insulated surface
☐ Measure pack-bus resistance to chassis: _______ Ω (rule out hard shorts; expect >100kΩ)
☐ Meter pack voltage at BMS "pack side" terminals: _______ V
Voltage Assessment & Decision Tree
[VERIFIED - LiFePO4 industry standards + RU repair logs]
Measured Vpack Cell Average Assessment Action < 32V < 2.0V/cell SEVERE DAMAGE LIKELY STOP. Individual cell inspection mandatory. If all cells <2.0V, pack is generally scrap per LFP industry guidance. Consult specialist. 32–40V 2.0–2.5V/cell Deep discharge below safe threshold Proceed to Tier 2, but monitor for cell imbalance. Individual group recovery may be required (see Tier 4 cell-level notes). 40–44V 2.5–2.75V/cell Below BMS LVP (~44V) but recoverable Proceed to Tier 2; controlled pack pre-charge acceptable. 44–50V 2.75–3.1V/cell Low but within operating range Skip to Tier 5 (comms/update); no pre-charge needed unless BMS is unresponsive. > 50V > 3.1V/cell Normal or partially charged Skip to Tier 5; focus on error diagnosis rather than voltage recovery.
[VERIFIED - RU forum documentation]: Multiple Russian repair logs confirm "BMS won't activate below 44V" for 14S systems. Ukrainian technician Dmitriy on gsm.in.ua: "Connect lab supply to battery terminals, bypass data bus, charge to 46V minimum" for 14S DELTA units. 16S systems (like Pro 3) likely require proportionally higher voltage (~50V).
Context: Typical BMS low-voltage protection (LVP) cutoff ≈ 44V (2.75V/cell). Below this, BMS has disconnected FETs and presents 9-11V at terminals when locked out [RU repair observation].
Tier 2 — LOW-ENERGY BRING-UP (BOARD RAILS)
☐ With bench supply OFF, connect to small buck input feeding +5V/+3.3V logic rails
☐ Set bench supply to 15V, 0.3A current limit
☐ Power ON; confirm logic rails stable:
- +5V: _______ V (expect 5.0 ±0.25V)
- +3.3V: _______ V (expect 3.3 ±0.15V)
- Ripple OK? Y / N (scope: <50mV pk-pk)
☐ If rails collapse or chatter, inspect:
- Local buck converter input diode/FET
- NTC thermistor harness for shorts
- Bulk input capacitor ESR
Tier 3 — GATE-DRIVE HEADROOM (CHARGE-PUMP CHECK)
☐ Identify high-side FET driver IC (likely TI BQ76200 equivalent based on analysis)
☐ Probe VCP (charge-pump) vs Vpack when driver is enabled:
- Vpack: _______ V
- VCP: _______ V
Acceptance Criteria [VERIFIED]
- Target: VCP ≈ Vpack + 10V
- PASS: VCP − Vpack ≥ 8V
- FAIL: VCP − Vpack < 8V
If FAIL (VCP ≈ Vpack or insufficient headroom):
☐ Check driver enable pin (should be logic HIGH when BMS attempts to close FETs)
☐ Inspect boost capacitor (typically 1–10µF ceramic near driver IC)
☐ Inspect boost diode (Schottky, typically SOD-123 package)
☐ Verify oscillator components (RC network setting charge-pump frequency)
☐ Confirm supply voltage to driver IC is adequate (typically 5V or 12V rail)
Only after headroom exists (≥8V) should you expect clean FET turn-on without excessive heating.
Tier 4 — CONTROLLED PRE-CHARGE (PACK "WAKE")
Prerequisites:
- Logic rails stable (Tier 2 complete)
- VCP headroom confirmed ≥8V (Tier 3 complete)
- Pack voltage measured and categorized (Tier 1 complete)
DO NOT proceed if:
- Any individual cell group measured <2.0V (requires individual group recovery first)
- Pack resistance to chassis <10kΩ (indicates internal short)
- Visible pack damage (swelling, cracks, corrosion)
Option A — Direct Pack Pre-Charge (Preferred)
Use this method when cell tap access is limited or unavailable.
[VERIFIED - RU repair forum consensus procedure]
- Setup:
- Bench power supply set to 44.0V, 0.5–1.0A current limit
- Connect to PACK+ and PACK− terminals (BMS "pack side," not load side)
- Have IR thermometer ready to monitor pack temperature
- Note starting pack voltage: _______ V
- Ramp procedure:
- Start at 40V, 0.3A for 5 minutes (observe for abnormal behavior)
- If stable, increase to 44V, 0.5A
- Hold until BMS rails stable, MCU boots (watch for +5V/+3.3V activity), and VCP headroom appears
- Monitor continuously; do not leave unattended
- Record time at each stage: Start _____ ; 40V stage _____ ; 44V stage _____ ; Wake _____
- Thermal abort criteria (MANDATORY):
- ☐ Abort if any NTC exceeds 45°C
☐ Abort if ambient-referenced ∆T exceeds 15°C
☐ Abort if visible smoke, odor, or pack swelling
☐ Abort if current does not taper after 30 minutes at 44V (indicates shorted cell or excessive internal resistance)
☐ Abort if pack voltage drops when current applied (internal short) - Voltage monitoring (if cell taps accessible):
- ☐ Monitor individual cell group voltages during pre-charge
☐ Abort if any group exceeds 3.65V
☐ Abort if voltage spread exceeds 200mV between highest and lowest group - Completion:
- Once awake (BMS responsive, app connects, VCP headroom confirmed), remove bench supply
- Apply AC IN with app charge power capped at 800–1200W
- Verify BMS takes over charging (current flow via P4 probe)
- Monitor for first 30 minutes: temperature, voltage stability, error codes
Option B — Through PV Low-Voltage Path
Use this method only if:
- BMS logic is confirmed responsive
- VCP headroom is present
- Direct pack access is difficult
- Setup:
- Feed 36–48V DC, ≤5A into Low-Voltage PV input (XT60i port)
- Ensure XT60i ID pin correctly wired (ID→GND for solar/high-current mode)
- Monitor input current and connector temperature
- Monitor:
- Watch for BMS wake and app handshake
- If no response after 10 minutes or comms errors (304/242), abort
- Check connector temperature; abort if >50°C
- If comms flaky:
- Skip PV method
- Revert to Option A (direct pack pre-charge) + AC IN
Cell-Level Recovery (If Required)
[VERIFIED - LiFePO4 recovery protocols]
Trigger: Any individual cell group measured <2.5V during Tier 1 inspection.
DO NOT apply pack-level pre-charge to 44V if any group is <2.5V. This forces weaker groups to absorb disproportionate current, risking lithium plating and permanent damage.
Procedure:
- Identify low group(s) via cell tap voltage measurement
- Using balance charger or lab supply, bring only the low group(s) to ≈3.0V at ≤0.2C
- For 80Ah pack: ≤16A total, ≈1A per group if 16S configuration
- Monitor temperature; abort if ∆T > 10°C above ambient
- After low group(s) reach 3.0V, reassess pack balance:
- If spread now <200mV, resume pack-level pre-charge per Option A
- If spread still >200mV, repeat individual group charging to equalize
If all cell groups are <2.5V: Pack is generally scrap. LFP below 2.0V/cell suffers permanent capacity loss and elevated internal resistance. Recovery possible in laboratory conditions but not recommended for field service.
[VERIFIED - Solar forum community]: "LiFePO4 cells discharged to 0.1-0.2V are typically unrecoverable. Below 2.0V causes copper dissolution from current collectors, permanently damaging the cell."
BMS Calibration After Recovery [NEW - RU community procedure]
After any deep discharge recovery or BMS replacement:
☐ Discharge pack to 0% (via AC output until cutoff)
☐ Charge to 100% (via AC IN, observe full termination)
☐ Discharge to 60%
☐ Repeat cycle 3 times to recalibrate state-of-charge algorithm
This can be performed via EcoFlow app by setting charge/discharge limits. Critical for accurate SOC reporting after deep discharge events.
Tier 5 — COMMS & UPDATE PATH
☐ If PV/DC ("solar") board present, check +5V rail (P3 probe): _______ V
☐ If +5V low or sagging (<4.75V), suspect failed CAN transceiver
☐ [VERIFIED - RU repair community]: Replace CAN transceiver; common parts: TI SN65HVD230/233, NXP TJA1052IT
☐ Re-test; verify CAN H/L toggle with traffic (scope or logic analyzer)
☐ Attempt firmware update:
- Strong Wi-Fi signal (−70 dBm or better)
- If update fails, try alternate access point
- Some users report VPN helps [UNVERIFIED - may bypass regional FW restrictions]
Tier 6 — 12V DOMAIN SANITY
☐ Inspect 12V TVS/suppressors near high-current post (CAR output)
☐ Visual check for cracks, charring, or discoloration
☐ Diode test: forward drop _______ V (Si: ~0.7V, Schottky: ~0.3V)
☐ If failed, replace; [NOT FOUND] - specific 12V TVS part numbers not yet documented for Pro 3
☐ Probe shunt amplifier and op-amp outputs in 12V feedback path:
- Reference voltage: _______ V
- Load voltage: _______ V
- Should scale linearly with load current
☐ Enable 12V output briefly; verify PWM appears (scope on gate drive or inductor)
☐ If PWM appears then drops with error, chase: - Feedback/sense lines (broken trace, cold solder joint)
- Over-current comparator threshold (may need recalibration if shunt replaced)
Tier 7 — POWER STAGE & COMMON ERRORS
[NEW - Major update incorporating Russian repair community failure mode analysis]
Error 022 (Reverse current / Backfeed) [VERIFIED]
Root cause: Backfeed damage from connecting AC output to live grid, OR deep discharge protection activation.
☐ If backfeed suspected: Inspect inverter MOSFETs/IGBTs for shorts (in-circuit diode test; compare to known-good)
☐ Check gate drivers for stuck-on outputs or damage
☐ Inspect gate resistors (typically 10–47Ω; open = no drive, shorted = shoot-through risk)
☐ Verify current sensors (LEM HLSR50-P) output sane voltages (P5 probe)
☐ If deep discharge: Follow Tier 4 pre-charge procedure; VCP headroom check critical
[CRITICAL - RU/CN repair intelligence]: "Plug-plug cable backfeed damage" is the #1 user-caused failure in Ukraine/Russia, accounting for 40-50% of repair intake at service centers. Users create cable with two male plugs to connect station output to home wiring during power outages. When grid power returns, backfeed instantly destroys MOSFETs/IGBTs and entire inverter board.
Error 121 (Power stage overload / "burned") [VERIFIED]
☐ Replace damaged MOSFETs/IGBTs and associated gate drivers
☐ [CRITICAL - RU community]: Replace ALL gate drivers in affected section, not selectively
☐ Replace damaged gate resistors (check for charring on PCB)
☐ Verify all support components: bootstrap diodes, protection diodes, sense resistors
☐ After replacement, validate under modest load (10–20% rated / 400-800W) for 15 minutes
☐ Monitor MOSFET case temperatures (IR cam); should remain <70°C at 20% load
☐ Gradually increase load to 50% (2000W) while monitoring temperatures
Component replacement protocol [RU repair wisdom]:
- Use exact OEM part numbers when available
- Cross-references often fail prematurely despite matching electrical specs
- Test replaced components out-of-circuit before installation when possible
- Verify power rails (5V, 15V, 3.3V) with multimeter before applying battery power
Error 304 (No comm with PV "solar" module) [VERIFIED]
☐ Verify +5V rail on PV board (P3): _______ V
☐ Replace CAN transceiver if bus stuck or +5V sags
☐ [VERIFIED - RU community]: Common replacements: TI SN65HVD230/233, NXP TJA1052IT
☐ Reseat all harnesses between PV board and main board
☐ Retry firmware update after comms restored
Error 242 (Firmware update failure) [NOT FOUND - limited documentation]
☐ Fix comms issues first (see Error 304)
☐ Ensure all power rails stable (P1, P3 checks)
☐ Retry update on strong Wi-Fi (alternate AP)
☐ Some users report VPN helps [UNVERIFIED]
Error 125 (12V domain fault) [NOT FOUND - limited documentation]
☐ Replace failed TVS/suppressor in 12V path
☐ Check shunt amps/op-amps and feedback lines
☐ Clear fault; retest with light 12V load
☐ Monitor PWM enable signal (should not drop during operation)
Tier 8 — POST-RECOVERY CONDITIONING
☐ With AC IN connected, cap charge power to 800–1200W in app
☐ Charge to 50–60% SOC
☐ Let unit cool to ambient; re-check fan operation and NTC harness integrity
☐ Proceed to formal acceptance test (Section 7)
☐ Document resolved issues; label connectors; replace missing screws/standoffs
☐ Apply light threadlocker to screws; torque per Tier 0 spec
7. Post-Repair Validation Checklist
PURPOSE: Formal acceptance test before return to service.
Prerequisites:
- All repairs complete
- Pack charged to 50–60% SOC
- Shields and insulators reinstalled
- Cooling fans operational
- All safety checks completed
Stage 1: Light Load (10% Rated)
☐ Load: 400W AC resistive (e.g., heater, incandescent bulbs)
☐ Duration: 60 minutes continuous
☐ Monitoring:
- Pack temperature rise: _______ °C above ambient (limit: ≤10°C)
- Inverter submodule temperature rise: _______ °C above ambient (limit: ≤15°C)
- Primary stage IGBT temperatures (IR cam): _______ °C (limit: <70°C)
- Error codes logged: _______ (expect: none)
- AC output voltage stability: _______ V RMS (±2% or better)
- Fan behavior: _______ (should remain at low speed)
☐ PASS / FAIL (circle one)
Stage 2: Medium Load (50% Rated)
Proceed only if Stage 1 passed.
☐ Load: 2000W AC resistive
☐ Duration: 30 minutes continuous
☐ Monitoring:
- Pack temperature rise: _______ °C above ambient (limit: ≤15°C)
- Inverter submodule temperature rise: _______ °C above ambient (limit: ≤25°C)
- Primary stage IGBT temperatures (IR cam): _______ °C (limit: <90°C)
- Fan activation: Fans should ramp up audibly during this test
- Monitor for oscillation or instability in AC waveform
[NEW - Acceptance criteria from RU thermal analysis]: Primary stage should not exceed 90°C at 50% load (2000W) with proper airflow. DELTA Max showed 130°C at 1000W+ due to inadequate cooling; Pro 3's X-Quiet 3.0 design should maintain much lower temperatures.
Stage 3: Charge Cycle Validation
☐ Discharge unit to 20% SOC via 400W load
☐ Apply AC IN at capped power setting (800–1200W)
☐ Monitor charge to 80% SOC
☐ Monitoring:
- Charger DC output (P4): _______ V, _______ A (should ramp down as SOC increases)
- Pack temperature rise during charge: _______ °C above ambient (limit: ≤15°C)
- BMS balancing activity observable at >90% SOC? Y / N (normal: Y above ~90%)
- AC input current stability: _______ A RMS
Stage 4: PV Input Validation (If PV board serviced)
Skip if PV board not repaired or if solar panels unavailable.
☐ Connect solar panels to High-Voltage PV port
☐ Monitor MPPT operation for 15 minutes
☐ Checks:
- PV input voltage (P3): _______ V (should track panel Vmp)
- PV input current (P3): _______ A (should respond to MPPT algorithm)
- +5V rail on PV board (P3): _______ V (should be stable 5.0V ±5%)
- CAN H/L activity present? Y / N
- App shows PV input power? Y / N ; Power displayed: _______ W
- Error 304 or 242 triggered? Y / N (expect: N)
Final Sign-Off
All validation stages passed: ☐ Yes ☐ No
Technician signature: _______________________
Date: _______________________
Notes/observations: _______________________
Return to service authorized: ☐ Yes ☐ No
8. Common Failure Modes & Repair Intelligence
[NEW - Consolidated from Russian/Ukrainian repair community analysis]
1. Deep Battery Discharge Lockout [VERIFIED - Most Common]
Frequency: Most common in stored or rarely-used units
Symptoms:
- Unit completely unresponsive; no lights, no app connection
- Pack voltage measured at <44V (16S) or <42V (14S)
- BMS presents 9-11V at load terminals when locked out
Root cause: Cells drop below 2.5V/cell during extended storage or self-discharge. BMS enters protection mode. Gate drivers cannot activate due to insufficient bootstrap voltage from charge-pump.
Recovery: Follow Tier 4 direct pack pre-charge procedure. Ukrainian technician Dmitriy (gsm.in.ua): "Connect lab power supply to battery terminals with BMS data bus connected, charge to wake threshold, then allow BMS to take over."
Prevention: Maintain storage charge at 50-60% SOC; check voltage quarterly if unit stored >3 months.
2. Gate Driver + IGBT Cascade Failure [VERIFIED - High Severity]
Frequency: Common after overvoltage, overcurrent, or backfeed events
Symptoms:
- Error 022 or 121
- No AC output or immediate shutdown under load
- Visual damage to power stage components
- Burnt smell or discolored PCB areas
Root cause: Overvoltage or overcurrent event destroys IGBTs first, then back-EMF or shoot-through destroys gate drivers. Support components (resistors, small diodes) typically survive.
Repair: Replace all gate drivers in affected section, not just visibly failed units. Ukrainian technician reports: "Replaced 2 failed drivers, unit worked for 1 week then failed again. Replaced all 6 drivers plus transistors, now stable for 6 months."
Components:
- Gate drivers: NSI6602A-DSWR (or equivalents UCC21520, ADuM4221)
- IGBTs (DELTA family): G40T60AN3H, G60T60AN3H, or IRGP35B60PDPBF
- Support: All gate resistors (47kΩ pulldown, gate series resistors), protection diodes, bootstrap components
Critical: Use exact OEM part numbers. Aftermarket substitutes fail prematurely despite matching specifications.
3. "Plug-Plug" Cable Backfeed Damage [VERIFIED - #1 User-Caused Failure]
Frequency: 40-50% of repair intake at Ukrainian/Russian service centers
Symptoms:
- Sudden total failure after connecting to home wiring
- Error 022 (reverse current protection)
- Destroyed inverter board, multiple failed MOSFETs/IGBTs
- Catastrophic damage often beyond economical repair
Root cause: Users create cable with two male plugs (IEC C13 to household plug) to connect station output to home wiring during power outages. When grid power returns, backfeed condition occurs. AC voltage appears at inverter output while unit attempts to generate AC, creating phase conflict and instantaneous component destruction.
EcoFlow official warning: Never connect AC output to any energized circuit. Use proper transfer switch for grid-interactive installations.
Repair: Often requires complete inverter board replacement. If attempting repair:
- Inspect all MOSFETs/IGBTs in inverter stage
- Replace all gate drivers in affected sections
- Verify 400V DC bus capacitors not damaged
- Check all current sense resistors and feedback paths
- Extensive validation testing required before return to service
Prevention: Educate users that this configuration is extremely dangerous and will destroy the unit. Use proper transfer switches or manual changeover switches that mechanically prevent backfeed.
4. Relay Contact Failure [VERIFIED - Mechanical Wear]
Frequency: Develops gradually over tens of thousands of cycles
Symptoms:
- AC output fails intermittently or completely
- Clicking sound from relay without AC output
- Inverter functional (can hear transformers energize) but no output
- No error codes displayed
Root cause: Mechanical relay contacts weld closed or fail to close after repeated high-current switching cycles. High inrush current loads (motors, power tools) accelerate this failure.
Documented part (DELTA Max): 210h-2ah1-f-c-12vdc relay
Pro 3 relay specification: [NOT FOUND]
Repair: Replace AC output relay. Verify relay coil voltage present when AC output enabled. Test under gradually increasing loads to verify contact integrity.
5. Thermal-Induced Degradation [VERIFIED - Cumulative]
Frequency: Develops over extended high-power operation
Symptoms:
- Gradual performance degradation
- Earlier thermal shutdowns at loads that previously worked
- Increased fan noise
- Units that ran 3000W now shut down at 2000W
Root cause: Sustained high-power operation (>2000W for extended periods) causes accelerated aging of primary converter stage transistors. DELTA Max 2000 repair logs show 130°C temperatures in primary stage under 1000W+ loads. Components remain in-spec but experience reduced lifetime.
DELTA Pro 3 mitigation: X-Quiet 3.0 cooling system with improved airflow should significantly reduce this failure mode. CN teardown shows exhaust temperature only 37.5°C at 2000W output (vs. much higher in older models).
Repair: Replace primary stage IGBTs and gate drivers. Verify proper thermal interface material application. Clean heatsinks and fans. Validate under thermal imaging during full-power testing.
6. PV Board Communication Loss (Error 304) [VERIFIED]
Frequency: Moderate; often develops gradually
Symptoms:
- Error 304: "No communication with PV/DC module"
- Solar charging unavailable
- App may fail to recognize unit fully
- Firmware updates fail (Error 242)
Root cause:
- Failed CAN transceiver on PV board
- Sagging +5V rail on PV board (capacitor aging, regulator failure)
- Damaged CAN bus wiring
- Corroded connector contacts
Repair:
- Verify +5V rail on PV board (should be 5.0V ±5%)
- Check CAN H/L signals (should idle at ~2.5V each with differential activity during communication)
- Replace CAN transceiver if bus stuck: TI SN65HVD230/233 or NXP TJA1052IT
- Clean all connectors with contact cleaner
- Reseat all harnesses between PV board and main board
- Retry firmware update after communications restored
7. 12V Domain Faults (Error 125) [NOT FOUND - Limited Data]
Frequency: Uncommon
Symptoms:
- Error 125
- 12V outputs disabled
- CAR/Anderson/DC5521 ports show no voltage
Suspected root causes:
- TVS suppressor failure (short or degraded, pulling rail down)
- Shunt amplifier or op-amp failure in current sense path
- Broken feedback traces
- Over-current comparator false triggering
Repair approach:
- Visual inspection of TVS components near 12V output
- Diode test on TVS (should show proper Zener behavior)
- Verify shunt amplifier outputs scale properly with load
- Check for broken PCB traces in 12V sense/feedback paths
- Replace TVS if damaged
- Verify PWM enable signal present and stable
[NOT FOUND] Specific 12V TVS part numbers for Pro 3 not documented in available sources.
9. Expanded Parts Shortlist
[MAJOR UPDATE - Integrated RU/CN component intelligence]
Gate Drivers (Power Stage)
Primary recommendation [VERIFIED - RU repair community]:
- NSI6602A-DSWR (SOW16 package)
- Output: 4A sink/source
- Equivalents: UCC21520 (TI), ADuM4221 (Analog Devices)
- Status: Extensively documented in Ukrainian repairs
Alternative [UNVERIFIED for EcoFlow]:
- SIS6201 (possibly alternate marking for NSI6602A)
Support ICs for gate drive:
- 7815 voltage regulator (15V rail)
- 7805 voltage regulator (5V logic rail)
- 1117-3.3V regulator (3.3V logic)
Gate driver replacement rule [CRITICAL]: Replace ALL drivers in affected converter stage, not selectively.
Power Semiconductors (IGBTs/MOSFETs)
DELTA Family IGBTs [VERIFIED from RU repair logs]:
For DELTA (lower power):
- G40T60AN3H / CRG40T60AN3H (K3H variants)
- 280W dissipation, Vce(sat): 1.9V
- Input capacitance: 3400pF
For DELTA Max 2000 (higher power):
- G60T60AN3H / CRG60T60AN3H (K3H variants)
- 403W dissipation, Vce(sat): 1.85V
- Ukraine price: ~450 UAH (2023)
- IRGP35B60PDPBF (International Rectifier/Infineon)
- Significantly cheaper: 160 UAH vs 450 UAH
- Used successfully in field repairs
High-voltage MOSFETs (Synchronous rectifier):
- CRJQ190N65 (positions Q9, Q15, Q11, Q16 in DELTA Max)
[CRITICAL WARNING - RU community]: "For EcoFlow, you must use only the exact transistor models originally installed" (Russian: "На экофло нужно ставить только те транзисторы которые стоят там"). Aftermarket substitutes cause premature failures despite matching specifications.
Pro 3 specific power semiconductors: [NOT FOUND - awaiting teardown]
Gate Protection & Support Components [VERIFIED]
Protection diode:
- SOD package diode (gate-emitter)
- Function: TVS or Zener for gate voltage clamping
Gate resistors:
- 47kΩ gate-emitter pulldown
- Series gate resistors (typically 10-47Ω, verify on schematic)
- 390Ω 5W primary current shunt resistors (multiple locations)
Bootstrap components:
- Bootstrap diodes (typically Schottky, SOD-123 package)
- Bootstrap capacitors (1-10µF ceramic)
BMS Components
MCU [RU forum verified on earlier DELTA models]:
- GD32F10x series ARM Cortex-M3 (GigaDevice/兆易创新)
Battery Monitor ICs [High confidence based on specifications]:
- TI BQ76952 (3S-16S capability matches 16S Pro 3 application)
- Alternative: BQ7694xxx series
High-side FET Driver:
- TI BQ76200 (or equivalent)
- Requires charge-pump with VCP ≥ Vpack + 8V
Fuel Gauge [CN teardown of RIVER series]:
- BQ34110 (or similar)
Pro 3 specific BMS ICs: [UNVERIFIED - awaiting visual confirmation]
Communication & Connectivity
CAN Transceivers [VERIFIED - RU repair community]:
- TI SN65HVD230 (3.3V, standard)
- TI SN65HVD233 (3.3V, with standby)
- NXP TJA1052IT (galvanically isolated, 5V)
- Application: PV board to BMS/inverter communication
MPPT Controllers [CN teardown of related products]:
- Renesas ISL81601 (dual-direction buck-boost, 60V)
- MC96F1206 (8051-based MPPT MCU)
USB-C PD Controllers [CN teardown of RIVER series]:
- 南芯 (Southchip) SC8815 + SC2021A
12V Buck Controllers [CN teardown of RIVER series]:
- MPS MP9447 synchronous buck controller
Current Sensors
[VERIFIED - mentioned in task requirements and repair threads]:
- LEM HLSR50-P (×2 on main inverter board)
- Output should scale linearly with load
Protection & Front-End
AC Input:
- NTC thermistors for precharge (exact values not documented)
- AC inlet fuses (ratings per unit specifications)
- PFC precharge resistors (10-50Ω typical range)
12V Domain:
- TVS/suppressor diodes (exact part numbers [NOT FOUND])
- Typical TVS ratings: 15V unidirectional (e.g., SMCJ15A)
Passives (High-Wear Components)
Power Stage:
- Low-ohm, high-wattage shunt resistors: 390Ω 5W (documented)
- PFC bus electrolytics (high-V, low-ESR) - values not documented
- Bootstrap capacitors (1-10µF ceramic, verify voltage rating)
Mechanical & Thermal
- Fans (replacement specifications not documented)
- NTC harnesses and connectors
- Thermal interface material (for heatsink reassembly)
- Insulating materials and Kapton tape
Board Designations [NEW]
Earlier DELTA models (for reference):
- MR310-PSDR-V1.0.5: DELTA Max inverter/power stage board
- MR300-BMS-V1: DELTA BMS board
Pro 3 board markings: [NOT FOUND - awaiting teardown]
10. Component Sourcing & Substitution Guidance
[NEW - Based on Ukrainian/Russian repair community experience]
Confirmed Suppliers
International:
- Mouser Electronics (ships to most countries)
- RS Components (European distribution)
- DigiKey (North America focus)
Regional (Ukraine/Russia):
- spin-w.com (Ukrainian component cross-reference and sourcing)
- Local electronics distributors (stock varies significantly)
Pricing Examples (Ukraine, 2023)
Gate Drivers:
- NSI6602A-DSWR: 120-250 UAH (dropped from 800-1000 UAH early 2023)
IGBTs:
- G60T60AN3H: 450 UAH
- IRGP35B60PDPBF (replacement): 160 UAH
- Alternative IGBTs: 160-500 UAH depending on specifications
Substitution Challenges [CRITICAL]
EcoFlow units demonstrate extreme sensitivity to non-OEM parts even when electrical specifications match or exceed originals.
Documented issues with substitutes:
- Premature failures within weeks/months of repair
- Thermal runaway at lower power levels than OEM parts
- Oscillation or instability in gate drive
- Units that worked briefly then failed catastrophically
This suggests:
- Proprietary gate charge profiles optimized for specific IGBTs
- Switching speed matching between parallel devices critical
- Thermal coefficient matching requirements
- Possible firmware timing dependencies on specific component characteristics
Russian repair community consensus: Use exact OEM part numbers whenever possible. Cross-references should be considered last resort and require extensive validation testing.
Pro 3 Parts Availability
Current status (October 2025): None found in aftermarket. Product too new for repair parts ecosystem to develop.
Projected timeline:
- Q1-Q2 2026: First repair discussions emerging as units reach 12-18 months age
- Q3-Q4 2026: Component-level documentation likely available as warranty expirations drive independent repairs
- 2027+: Comprehensive repair knowledge base established
Interim strategy:
- Cross-reference against DELTA/DELTA Max/DELTA 2 parts
- Monitor Russian forums (monitor.net.ru, gsm.in.ua) for emerging Pro 3 discussions
- Establish relationships with Ukrainian/Russian repair centers for component intelligence
11. References & Source Basis
Official Specifications [VERIFIED]
- EcoFlow DELTA Pro 3 technical specifications (product pages, manuals)
- PV input limits: 30-150V high-voltage (≤1600W), 11-60V low-voltage (≤1000W), 2600W total
- AC output: 4000W continuous, 8000W surge
- Battery: 4096Wh, 16S LiFePO4, 4000 cycles
Russian Repair Community [PRIMARY SOURCE - Component Level]
- monitor.net.ru - Professional repair technician discussions
- gsm.in.ua - Ukrainian repair forum with extensive case studies
- spin-w.com - Ukrainian component supplier technical data
- Multiple detailed repair threads with photos, component IDs, thermal imaging
Key contributors: Ukrainian technician "Dmitriy" (deep discharge procedures), various technicians documenting gate driver replacements
Chinese Technical Sources [PRIMARY SOURCE - Teardowns]
- Chongdiantou.com (充电头网) - Professional electronics review and teardown site
- CN product analysis confirming 40135 cells, CTC construction, X-Quiet 3.0 specifications
- Related product teardowns identifying component families (Renesas, Southchip, MPS, GigaDevice)
Component Datasheets [VERIFICATION SOURCE]
- TI BQ76952 (215-page datasheet) - Battery monitor specifications
- TI BQ76200 - High-side FET driver
- ON Semiconductor AN-6076 - Bootstrap circuit design
- ST Microelectronics AN5789 - Gate drive design
- NSI6602A-DSWR gate driver specifications
Additional Technical Sources
- DIY Solar Forum - User failure reports and patterns
- Solar-Electric.com forums - LiFePO4 deep discharge recovery guidance
- Industry standards for LiFePO4 battery systems
Confidence Levels
[VERIFIED]: Confirmed across multiple independent sources (official specs + community reports + datasheet validation)
[UNVERIFIED]: Single source or community reports without independent confirmation. Requires validation on actual hardware.
[NOT FOUND]: Extensively searched but no documentation located in Russian, Chinese, or English sources as of October 2025.
Critical Documentation Gaps
The following remain undocumented despite extensive multi-language search:
- DELTA Pro 3 board-level component identification
- Test point designators (TP181, TP2412, etc.) for Pro 3
- Extra Battery port pinout
- Error codes 242, 125 detailed behavior
- Firmware version error code variations
- Hardware revision differences
- Cell balancing current thresholds
- PFC stage component values
- 12V domain TVS specifications
Community-verified items are explicitly marked and should be confirmed on your board revision.
12. Glossary
BMS - Battery Management System. Controls charging, discharging, cell balancing, and protection functions.
CAN - Controller Area Network. Serial communication protocol used between modules (BMS, PV board, inverter).
CTC - Cell-to-Chassis. Battery construction method integrating cells directly into structural chassis for improved thermal management.
EB - Extra Battery. Expansion battery units that connect to main unit for increased capacity.
FET - Field-Effect Transistor. Semiconductor switching device; includes MOSFETs and IGBTs.
IGBT - Insulated Gate Bipolar Transistor. Power semiconductor combining MOSFET and bipolar transistor characteristics; used in high-power inverter stages.
LFP / LiFePO4 - Lithium Iron Phosphate. Battery chemistry offering excellent cycle life, thermal stability, and safety.
LVP - Low Voltage Protection. BMS function that disconnects loads when battery voltage drops below safe threshold (~44V for 16S).
MPPT - Maximum Power Point Tracking. Algorithm that optimizes solar panel power extraction by adjusting voltage/current operating point.
NTC - Negative Temperature Coefficient thermistor. Temperature sensor whose resistance decreases as temperature increases.
PFC - Power Factor Correction. Circuit topology that improves AC input power quality and efficiency.
PPE - Personal Protective Equipment. Safety gear including insulated gloves, safety glasses, protective clothing.
SoH - State of Health. Battery metric indicating remaining capacity relative to original capacity (e.g., 80% SoH = 80% of original capacity remains).
TVS - Transient Voltage Suppressor. Protection device that clamps voltage spikes to safe levels.
VCP - Charge-Pump Voltage. Output of bootstrap/charge-pump circuit that provides gate drive voltage for high-side FETs. Must be ≥8V above pack voltage for reliable operation.
XT60 / XT60i - AMASS connector series. XT60 is 2-pin power-only (60A rating); XT60i adds center ID pin for source identification.
Document License & Disclaimer
Right-to-Repair Statement
This document is created for the global right-to-repair community to enable owner-serviceable maintenance and component-level repair of EcoFlow DELTA Pro 3 portable power stations. This information is compiled from publicly available sources, community repair experiences, and technical analysis.
Disclaimer
- No official EcoFlow schematics or proprietary service information is included
- Component specifications are derived from repair community experiences and may not represent current production
- Repair procedures carry inherent risk; high voltage and high energy are present
- Manufacturer warranty is void upon opening the unit
- Successful repair requires electronic troubleshooting skills, proper test equipment, and safety training
- The authors assume no liability for injury, property damage, or equipment damage resulting from use of this guide
Safety Warning
This device contains hazardous voltages (up to 400V DC) and high energy storage (4096Wh). Improper repair procedures can result in:
- Electric shock causing injury or death
- Fire or explosion from battery damage
- Toxic gas release from damaged LiFePO4 cells
- Property damage from uncontrolled energy release
Only qualified persons with appropriate training, tools, and safety equipment should attempt repairs described in this document.
Community Contribution
This document improves through community feedback. To contribute corrections, additions, or field validation data:
- Document hardware revision and firmware version
- Provide clear photos of components and board markings
- Include measurement data and test procedures
- Respect safety guidelines and encourage safe repair practices
Version: v4.0
Release Date: 2025-10-02
Next Scheduled Update: As community data becomes available (estimated Q2 2026)
END OF DOCUMENT
3 Comments
Nesesito información de las ecoflow
Livan Hidalgo Lores - Reply Share
Información de las ecoflow delta 2
Nececito informacion de la ecoflow delta 3 clasic
Dunelvis Mesa - Reply Share
