Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera stability is poor
Video footage is shaky and unclear due to an unstable camera
Screws that hold the camera in are loose
You need to get to the screws and replace them or tighten them. You can do this by using this guide.
Plastic cover over the camera lens is broken or cracked
Replace the camera lens using this guide.
Drone will not land properly
Drone is not able to land on all four legs without tipping or falling over
A screw is lose within the leg
First make sure that all of the legs are down and in ready position for landing. If all the leg stands are in landing position and it still wont land properly, then you may have a problem with the screws that hold the leg in. Replace or tighten the screw in the leg using this guide.
One or multiple of the leg stand are cracked
First make sure that all of the legs are down and in ready position for landing. If all the leg stands are in landing position and it still wont land properly, then one of your leg stands may be cracked or broken. Replace the leg with the proper tools using this guide.
Propeller is bent or broken
The propeller looks like it is bent or cracked
Drone is flying but is not flying straight
You can try to use a subtle heat source like a lighter to heat the plastic up to bend it straight. Be careful not to bring the lighter too close to the drone as you could possibly melt the plastic too much. 2.5 - 3 inches away is a good length. If the drone is still not flying straight then you will need to replace the propeller by using the steps and tools in this guide.
Drone will not fly at all
You will need to replace the propeller using the proper tools by following this guide.
Propeller(s) will not spin
You will need to take the propeller off and see if there are any strings or threads tangled in the propeller. If all the propellers are not spinning It could be a bigger problem with the motor. However, if just one is not spinning and you are unable to find threads or string then you can try to replace the propeller using this guide and the proper tools.
Drone will not connect to Bluetooth
When trying to connect your phone to the drone to control it, it will not connect to your Bluetooth device.
Something is broken within the motherboard
You need to replace or fix something on the motherboard. You can locate and remove the motherboard using this guide.
One of the wires connected to the motherboard is broken or disconnected
You need to get to these wires and replace any that are broken or disconnected using this guide.
Wes Knutson
481 Reputation
3 Guides authored
UW Stout, Team S6-G5, Ogden Fall 2018 Member of UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Members
48 Guides authored
8 Comments
I’ve had my Breeze 4K drone for one year. I haven’t flown it in a few months. Batteries are fully charged but the drone won’t power on. Help!
Cheryl Lee - Reply Share
Breeze drone app keeps saying update before next flight but will not update keeps saying network anomaly
Terry Freeman - Reply Share
Drone wont start up had indoor flight once
zoog3 - Reply Share
hi how come my yuneec breeze wont take off battery is fully charge & drone was connected to wifi , although i dont see the camera is on, 2nd i dont see the top icons ( GPS, battery indicator wifi indic.? all icons indicator on top wont turn to blue, 3rd when i calibrate it says insufficient batt. but the batt i charge it overnight, please help me to trouble shoot my problem thanks
ve6czr - Reply Share
Hello I had the same problem and I found out it was my WiFi it must have internet connection when connected
Timothy Bernard - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 3,723
