Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Xkey Mobile Music Keyboard
Xkey Mobile Music Keyboard Model Number: KX01U14 Date released:
Won't connect via USB
An outside source can not be connected via the USB port.
USB entrance piece is dented or physically impaired
To test this, try to insert a USB cord without struggling. If you struggle remove the cord and look directly at the input place to detect any dents or physical imparities. If the entrance USB piece is simply not in place, use a tool from the "Pro Tech Tool Kit" to move the piece back into place. If the piece is dented, try to reduce the dent with a tool by applying pressure to the area or simply replace the USB port piece.
Buttons will not respond
"When attempting to press buttons on the keyboard they do not respond with the desired result"
Device may need resetting
In order to reset your device to factory default you would need to press and hold Oct +/- ==> while you are connected with the USB cable.
Another way to reset this device will be to use the Xkey plus reset to factory button and try again.
The buttons may be physically worn
To fix this issue you would need to contact www.cme-pro.com to order the replace parts and contact your local electronic repair shop.
Silicone button covers come off
"The buttons on the keyboard made of silicone are continuously coming off"
Flaps of the button may be out of place
You can use a tool from the "Pro Tech Tool kit" to push the flaps of the button back into place.
The silicone button itself may be ripped
If this silicone piece is ripped then you would need to contact www.cme-pro.com and order a replace button piece. You can insert this yourself or contact your local electronic repair shop.
Light for the USB connecter won't turn on
" The light detecting whether the device is on or off will not come on"
Make sure the USB is connected to a power source
May need factory resetting
Any issues that are "non-fixable" there is a two-year warranty on this device
Bree
51 Reputation
0 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2018 Member of USF Tampa, Team S1-G3, Leahy Spring 2018
USFT-LEAHY-S18S1G3
3 Members
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,409
