Vaio FS VGRFS640 Troubleshooting
How to Remove the Back Plate
Step 1:
Remove battery in back of computer by pushing locks inward and sliding the battery
out picture of battery location and directions for listed actions
Step 2:
Remove back plate of laptop by unscrewing the (number) securing screws.
picture of back plate labeling type number and location of screws
Step 3:
Remove plates that secure back plate and hide screws picture labeling sliding plates
with screws removed and the screws that were hidden and removed
Step 4:
Remove plate by gently prying edges of laptop picture of laptop with plate removed
showing the CD/DVD drive
How to replace a the CD/DVD drive when it displays an error
Step 1:
Unscrew the (number) securing screws around the disc drive. (Picture of disc drive
area with securing screws all numbered.)
Step 2:
Carefully slide out disc drive removing. (Picture of removed disc drive)
Step 3:
Check area where disc drive goes for any abnormalities (Cracks, particles, blockages
etc)(Picture of DD area potentially with man made blockage.)
Step 4:
Carefully slide in new/repaired disc drive. (Picture of disc drive partially slide in with
arrow showing direction to push.)
Step 5
Screw in the (Number) securing screws around the disc drive (Picture of disc drive area
Step 6:
Re-secure plates that secure back plate by screwing in (number) screws picture
labeling sliding plates with screws numbered.
Step 7:
Re-secure battery in the back of the computer by sliding battery into slot and pushing
locks outward to lock battery in. (Picture of battery location and directional for listed
actions.)
What to do with bad battery
If your CPU won't turn on, Try replacing the batteries since it might be dead.
How to clean the fan
Step 1:
Step 2:
Remove back plate of laptop by unscrewing the (number) securing screws picture of
Step 3:
Step 4:
Unscrew previously hidden screws picture labeling screws
Step 5:
Step 6:
Unscrew the (number) securing screws around the fan. Picture of fan area with
Step 7:
Carefully remove fan. Picture of removed fan
Step 8:
Blow what dust you can off the fan.
Step 9:
Get a damp paper towel or napkin, it should not be dripping, merely damp to the touch
picture of damp paper towel, good and bad.
Step 10:
Wipe off remainder of accessible dust. (Picture of cleaned fan)
Step 11:
Place the fan back in, in the same position it came out in. (Picture of fan)
Step 12:
Re-screw the (number) securing screws around the fan.
(Picture of fan area with securing screws all numbered.)
Step 13:
Place the plate back on gently pressing the edges down. (Picture of plate, correctly on,
with screws removed.)
Step 14:
Rescrew all screws.
(Picture labeling all screw holes and color coded by type.)
Step 15:
Replace the smaller plates covering the hard drive and memory cards. (Picture labeling
them placed in.)
Step 16:
Screw in the plates covering the hard drive and memory cards. (Picture labeling them
screwed in place.)
Step 17:
Place battery back in and lock it. (Picture labeling the battery and locks as well as lock
directions.)
How to replace a broken key
Step 1: Remove the locking bar and unscrew the screws that hold the keyboard in.
Step 2: Unplug the cable that connects it to the motherboard which is the ribbon cable.
Then lift the keyboard slightly and out. So that it won’t damage the motherboard and
other pieces.
Step 3: Install the new keyboard. After plugging the new keyboard in, slip it into place
and screw the keyboard in. Finally, snap the lock bar back in.
Step 4: Now try to use the keyboard to make sure it works. Since some refurbished
ones might have bad keys.
How to fix a crack in the body of the laptop
Step 1:
Make sure the damaged area is clean and free of dirt and loose pieces.
Step 2:
Then prepare the putty. It comes as a cylinder with two components wrapped
around each other. Just cut a section off and twist the parts together. Then mix the
two putty components completely with gloves because of the chemicals in the material.
Step 3:
Press it firmly into the hole in the case and use your finger or a razor blade to
shape it to follow the contour of the case. When it covers the area, take the flat side of
a razor blade or back of a ruler and compress the outer surface to flatten it. Any excess
putty can be wiped off the case with paper towel before it dries. Then wait for an hour
or two to let it dry.
Step 4:
Press the putty into the damaged area and flatten the outer surface.
Step 5:
Finally steps are sanding the dried patch with increasingly finer sandpaper and
painting it to match the case.
Checklist
- Does your CD/DVD drive when displays an error?
- Did your battery died?
- Is your fan making noise?
- Have you checked if any of your buttons are broken?
- Does your laptop have a crack?
http://en.wikipedia.org/wiki/Sony_Vaio_F...
http://www.cnet.com/products/sony-vaio-f...
http://www.wikihow.com/Install-a-CD-ROM-...
http://esupport.sony.com/US/p/model-home...
http://smallbusiness.chron.com/clean-lap...
http://www.pcworld.com/article/171753/la...
Kiet
1 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 430
