Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Consistently low battery
“The tablet will not maintain a reasonable charge.”
Faulty Outlet
If your tablet will not charge while it's plugged in, it might be the outlet you're using. Try plugging the charger into a different outlet.
Faulty Charger
If you tried to plug your charger into a different outlet and it's still not charging, then you could have a dead charger. Replace your charger with a new one.
Dead Battery
After trying to plug your device into a different outlet and replacing your charger and the tablet is still not charging, the battery will need to be replaced. Follow the Battery Replacement Guide to safely change out the battery on your Supersonic tablet.
Device Will Not Restart
"Your device will not restart when you press and hold the power button."
Faulty Power Button
To see if your device has a faulty power button, first test the power button capability by pressing once to turn the screen off and again to turn it back on. If the power button responds, you need to restart your device manually. However, if the screen does not turn off and on, your power button is faulty. This attachment can not be replaced, so replacing the Motherboard should help with the circuiting of the device. Click here for the Motherboard Replacement Guide.
Device Won’t Unlock
“Your device will not unlock for usage.”
You Forgot the Password
If you forget your password, you will need to manually reset your device. Hold down the power button to shut down and turn the device back on. Once finished, open your device, go to settings and set a new password.
Touch screen Is Unresponsive
“Your touch screen is not responding to your finger or a stylus.”
Dirty Screen
When your touch screen is delayed or not responding to touch, you may need to clean the screen. Use a lint-free cloth to wipe any residue off the screen.
Sensor Is Broken
If your screen is completely unresponsive after cleaning, your sensor is broken. Therefore you will need to replace the sensor using the Sensor Replacement Guide.
Screen Freezes
“The screen freezes when you turn on, use or open/close applications.”
Out Of Date Software
Your device could be out of date. You should navigate to the “settings” application, and then navigate to the software/update section. If there is an update available, you should update your device. Not updating it will slow it down and cause it to malfunction.
Faulty Hard Drive
If your devices’ software is up to date, your Supersonic may need a reset to clear its processing system. This can be done by simply restarting the device. Hold down the power button to shut down and turn the device back on.
Buy A New Device
The last resort for a situation like this would be to contact customer support asking for a refund or for them to replace the device. Make sure you have proof and have examples to share with them. If they refuse to do anything about the situation, you may have to buy a replacement device.
Inadequate Sound Quality
“Speaker sound quality is inconsistent in volume when listening to music or watching videos.”
Speaker Replacement
If there is no sound coming out of the device speakers, you may need to look into replacing the speaker. Click here for the Speaker Replacement Guide.
Poor Camera Quality/Resolution
“Your camera does not focus and your pictures taken are low quality.”
Camera Replacement
When using the camera to take pictures, you are unable to capture anything or it is of low quality. You may need to replace your camera using the Camera Replacement Guide.
2 Comments
Where doesthe charger go?
Lisette Pacheco - Reply Share
I purchased a supersonic gray wireless speaker and yesterday it was working now there is no power at all, what's going on, can you help me fix the problem?
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,758
