Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Phone Does Not Power On
Users may complain of the phone not powering on and not being able to use it for their needs.
Battery Has No Charge
Your device may not have any charge in the battery left. Attempt to press the power button for five seconds to make sure that the phone is unresponsive to being turned on. It may show an empty battery, indicating that you must charge the phone. Make sure that the phone has been connected to a working charger for at least one hour before trying again.
Charger Does Not Work
The problem may be your charger. If the battery is known to be working, plug in the charger. Check to see if there is a charging symbol that displays on the screen. If the symbol is not apparent or it does not show consistently, then your charger may be faulty. You can buy another charger from here , or if you want to save money, you can use any USB Type C cord in your house and substitute it as a charger!
Battery is Dead
The problem may also be a dead battery. If the phone does not turn on at all, you should follow this guide in order to change the battery.
Motherboard is Bad
If no other solutions work, the phone’s motherboard may be faulty. Follow this guide to replace the motherboard.
The Phone Has Slow Performance or Lag
Sometimes your phone will seem to respond slowly to user inputs or even crash when running process intensive applications.
Phone Has Been on For Too Long
Your phone may be getting tired after being awake for so long! Give it a break by restarting it, holding the power button, and turning it on accordingly. This helps clear out memory and can clear out sticky background processes and applications.
RAM is Full
Your phone may have too many processes running at one time. Close out of applications that are not in use to reduce the amount of RAM in use. You can also enable SMART CLEANER in your device's settings to automatically reduce RAM usage from background and unused apps. Smart Cleaner can be enabled by going to Settings, tapping Storage & Memory, and enabling Smart Cleaner. You should also disable unused home page widgets by unlocking your device, holding down on the unwanted widget, and dragging it to the remove icon.
Memory is Full
Your phone may be running out of memory. Go to your settings and press the applications tab. Select any applications that you rarely use and select the delete button to free more memory. Your device should be running more smoothly afterwards.
The Battery Will Not Charge
Users sometimes find that their device will not connect via USB port, not allowing for data transfer through tether or charge to be accumulated on the battery.
Charger is Broken
If the battery is known to be working, the problem may lie in the charger. Plug in the charger to a power source and your phone. Check to see if there is a charging symbol that displays on the screen. If the symbol is not apparent or it does not show consistently, try plugging the charger’s wall hub to another socket. If it still does not work, try a different charger.
Phone is Not Accepting Power
The problem may be the obstruction of electricity flow to your device. Clean the bottom of the USB port and ensure that it is not wet or clogged with lint/dust. If this does not work, the problem may be missing/corroded pins in your phone. If this is the case, you may need to replace your USB port. Follow (this guide) to learn how to replace your device’s USB port.
Battery is Dead
The problem may be a dead battery if the phone does not turn on at all. Follow this guide in order to change the battery.
The Camera's Quality is Compromised
The camera quality of the phone may be blurry, cracked, or seem to have debris on the lens.
Camera Lens is Cracked
The camera’s glass is cracked and may need replacing. Follow the guide at the bottom of this section to learn how to replace the camera.
Photos are Blurry
The camera may have some oil or fluid on it that dried. You can take it out to clean it following the guide at the bottom of this section.
Front Camera Replacement
The Headphones Have No/Distorted Audio
Users often complain that the audio they hear from the headphones is distorted but is not distorted when they use their headphones on an another device.
Speakers/Headphones are Faulty
If the headphone jack is not the problem, the system speakers may have malfunctioned. In this case you may need to buy another set of headphones!
Headphone Jack is Faulty
Knowing that your headphones are functional, the problem may be an incomplete connection between your earphones and device. Clean your headphone jack to make sure that it does not have lint/dust and is not wet. If that does not work, you may have to replace your headphone jack. Please follow this guide to learn how to replace your device's headphone jack.
Jett Bolusan
51 Reputation
0 Guides authored
Cal Poly, Team S18-G2, Livingston Spring 2018 Member of Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Members
72 Guides authored
1 Comment
Can anyone please explain why my Screen on my Sony Xperia XZ PREMIUM blacksout when making a call.
When on Bluetooth it does not blackout.
Warren Harrington - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 5,193
